Does the GTM use the Corvette LS1 or the Camaro/Firebird LS1 belt pulley spacing?
Corvette spacing on everything. If you're doing a crate engine, you will have to install the older C5 water pump that has the large bell-shaped pulley. The newer waterpumps with the flat pulley are too thick at the t-stat housing and the housing will hit the chassis.
Shane Vacek
VRaptor SpeedWorks, LLC
www.vraptorspeedworks.com
Here is the water pump that I use...
https://www.summitracing.com/parts/gmb-130-7290
