Steering arm to spindle mounting bolts
The manual shows using button head bolts to mount the steering arm, but none were shipped. I was shipped standard 1/2" bolts along with some 1/2" 12 Point bolts with the same threads.
The manual doesn't specify which parts to use, so I am asking for some direction / help before I put the spindles on & torque them down.
They no longer use the button head. They are standard bolts with a flange lock nut. the 12-point bolts are to mount the caliper.
Kevin, be sure you get the arms on the correct side.
Mrk III, 331 stroker, Borla stack injection, T5, 3:55 IRS, Power steering and brakes. Kleiner body & paint
On behalf of all of us who screwed this part up—I can’t stress enough how important this is to get right the first time!
