Thread: Useless clock
    May 2022
    Fishers, Indiana
    Useless clock
    I have the speedhut gages that includes a clock. I would like to replace the clock with a different matching gage.
    Anyone done this? What gage did you replace it with?
    Lilburn, GA
    Some people use a oil temperature instead.
    Senior Member F500guy's Avatar
    Aug 2022
    Portland, Oregon
    I got an oil temp gauge from speed hut, unfortunately the font is not quite the same so make sure you get them to match.
    MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
    "Build a Car" They Said "It Will Be Fun "
    Aug 2012
    Grand Rapids, MI
    Just an FYI, I consider the oil temp one of the 3 important gauges, but I base choices on road track time. Oil pressure, oil temp and tach are in front of my steering wheel. In my experience water temp is important on the street but running on the track and moving water temp is seldom a problem.
    Everyone has their preferences and concerns.
    Jim
  5. Likes johnnybgoode liked this post
    Senior Member JIMOCO's Avatar
    Aug 2013
    Camp Hill, PA
    In addition to oil temp I added a vacuum gauge. You can get great info about the health of your engine.
    Mk4 Roadster, Picked up complete kit 8/22/14. Most FFR options except Wilwood brakes and IRS. First start 11/11/14. Go-kart 3/8/15. 347 Stroker, TKO 500, 3-link/3.27 rear. PA street legal 7/29/15.
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    I swapped my clock out (later on) for Wideband AF gauge. I actually went with the AEM unit, since it was pretty close in style to my Speedhut gauges. Not a perfect match , but.. close enough for me at least.
    2016 MK4 | '99 Explorer 5.0 | E303&600cfm carb | T5z + 3.55 | 3-link | SN95 | PB/PS | FR500 17" 315&275 |
