Can anybody out there help me out on which arms and blades to order for my wiper kit I just got from Specialty Power windows
For the Coupe? i guess that I should get bent right arms, and blades for curved glass. Not sure how to measure for these.
I have the same wiper kit, and went with some length and angle adjustable arms from Sea Dog. Kinda made for the boating world, but work well on the curved glass. I had to modify the length adjustment (cut some off of an arm length, then re-inserted). They have several different types and lengths Here are 2 examples
https://www.walmart.com/ip/Sea-Dog-4...inch/655076464
https://sea-dog.com/groups/1920-adju...arm-hook-style
I know they had an 8" length arm somewhere too - can't find it at the moment. Drivers side blade worked out to be 15" I think? and Pass was 11". With those blades, the drivers side arm needed a slight angle adjustment in the arm, along with the length trimming I mentioned. The passengers side worked out fine with a straight arm. Both are "J-hook", and I preferred that as they're easy to get at most auto parts stores. Arms I went with are black powder coated stainless steel which I preferred as well.
One option.....I'm sure there are several others too
Rian
Look on Paul's build starting at post 1126,https://thefactoryfiveforum.com/show...-Report/page29. I fould some wiper arms made by Autotex ,but they are backordered as of right now. You can get them on Grainger, but they are 50% more. I have not found any others yet that have the swivel head. I am also not sure if that is required.
https://getautotex.com/products/2007...22-8-11-radial
Some of their smaller products came with swappable head mounts (2 different spline attachments), but the rest came with the the correctly sized parts (1/2" spline) to mate up with the SPW wiper kit. Also, you can swap off the mounting head to the SPW kit if need be.
RR
Some pics of the attachement points etc from the wiper arms that I referenced:
2024-01-31 15.12.37.jpg2024-01-31 15.12.44.jpg2024-01-31 15.12.52.jpg2024-01-31 15.13.28.jpg
