Results 1 to 9 of 9
Thread: Aod to 4r70
    Mar 2023
    Aod to 4r70
    Want to changeout my ford aod to a 4r70. Anybody know what parts or any changes that I would have to do? Heard the 4r70 is about a inch longer, would that be my only concern?
    Jan 2012
    Central OK
    The 4R70 is also electronic, so you need a shift controller.
    Kyle
    Mar 2023
    Yes, a stand alone kit, since I have a blueprint 347 with a fitech.
    Dec 2020
    Hope you can document your changeout and share here.
  5. Likes Geoff H liked this post
    Jan 2012
    Central OK
    Oh, and JimS noted that the slip yoke for the 4R70W has a larger outer diameter:
    https://thefactoryfiveforum.com/show...l=1#post523486
    Mar 2023
    Looks like I need to pull my engine and transmission. Anybody drop the trans from underneath. Don’t look possible to me.
    Jul 2022
    Wellsboro, PA
    The 4R70W driveshaft yoke is unique to the 4r70. I used Dane / Spicer 2-3-14061X, 1330 joint.
    The trans controller I used came from Blueprint and it's a UShift controller (Blueprint 347 with 4R70W, and Sniper).
    And I chose to eliminate the speedo sensor on the tailshaft, added a block off plate. I plan to get my speedo signal from the UShift controller, it monitors the output shaft speed sensor.
    Don
    1990 Mustang 5.0 5sp, 2021 Bronco Sport Badlands, 1935 Extended Cab Build, 347 & 4R70W
  9. #8
    Senior Member Crawleyscobra's Avatar
    Quote Originally Posted by k808 View Post
    I don't know about an AOD, but I just dropped my TKO-600 from the bottom on a MK III Roadster.
    I'm swapping out my TKO to install a 4R70W from the bottom.
    I currently have an empty case that I am using for a mockup install.
    FFR6682 - received 7/30/08 - MK 3.1 complete kit, Forte built Ford Racing BOSS 427W(475HP/500lbs), TKO600, Power steering, Power Brakes, Hydraulic Clutch, VPM Front/Rear sway bars, Bump steer kit, SAI mod, 13"Front/11.65"Rear Mustang Cobra rotors w/calipers, NITTO NT05s - 255/40R17-Front, 315/35R17-rear,3.55 IRS.
    Visit my Blog: http://crawleyscobra.wordpress.com
  10. #9
    Mar 2023
    Factory five said I would need to remove trans from inside of cab. Trans shop got it out, and is currently rebuilding my aod(which was stock) to handle my 347. But now I have another problem. Just got a 05 van with a 6.0 w/4speed auto(for free with only 80,000 miles). I really want to switch over to the 6.0 in a few years time.
