Hello all. My name is Pete and I'm working on the direction I want to go with respect to brakes on my build. My question is in regards to the front spindles supplied by FFR. I want to use the Ford Performance GT350R Brake kit. I'm curious if the FFR spindles are similar to the stock 15-23 Mustang spindles so that the brake kit will fit. It appears that the Brembo calipers use a radial mount adapter that bolts onto the spindle. I'm using a 2018 IRS out back so I'm all good on that end. Thanks.
