Results 1 to 4 of 4
Thread: New builder has spindles/brakes question
    Jan 2024
    Hello all. My name is Pete and I'm working on the direction I want to go with respect to brakes on my build. My question is in regards to the front spindles supplied by FFR. I want to use the Ford Performance GT350R Brake kit. I'm curious if the FFR spindles are similar to the stock 15-23 Mustang spindles so that the brake kit will fit. It appears that the Brembo calipers use a radial mount adapter that bolts onto the spindle. I'm using a 2018 IRS out back so I'm all good on that end. Thanks.
    Pretty sure they are not a direct bolt on. Maybe someone makes an adapter.
    Edmonton Alberta
    I believe they are similar to SN95 spindles
    David W
    Mkll 4874 built in 2004
    Jan 2024
    Thanks for the input. Further research leads me to believe that It may be as simple as a custom radial mount. Once I have the spindles/ hubs/ rotors/ calipers in my possession I will get working on one.
