Do these rear brakes come with hardware that allows them to be mounted to a 8.8” rear axle?
If not, where can these adapters be sourced?
Bob G.
Bob G.
I've used that same brake option on two builds with 8.8 solid axles -- a Roadster and a 35 Truck. They come with the hardware and mounting brackets. No additional parts required. Note they are single piston with integral e-brake. Work fine, but not the same as the four piston with separate e-brake setup used on IRS builds.
