Results 1 to 3 of 3
Thread: Wilwood rear brakes, 12.19”, FFR item 60423
    Jan 2024
    Do these rear brakes come with hardware that allows them to be mounted to a 8.8” rear axle?
    If not, where can these adapters be sourced?
    Bob G.
    Oct 2023
    Greenwood, Indiana
    Quote Originally Posted by Rleog View Post
    Bob G.
    Everything should be specific to the rear you have selected. All parts come from Willwood. Yes they have all brackets and hardware specifically for the rear package chosen.
    I hope this helps.
    Michael
    I've used that same brake option on two builds with 8.8 solid axles -- a Roadster and a 35 Truck. They come with the hardware and mounting brackets. No additional parts required. Note they are single piston with integral e-brake. Work fine, but not the same as the four piston with separate e-brake setup used on IRS builds.
