New kid (old person) The journey Begins MK IV 347 EFI
Good afternoon All!!
Well after lengthy review of the build blogs, I have pulled the trigger and ordered my MK IV kit. I got a call today that it will be available for pickup on March 23rd. Woohee!! Can’t wait to get started! I attended the build school earlier this year (January) and it gave me enough confidence to build the car! I have no experience in “wrenching” but are pretty good at following directions. I will look to the Factory Five Forum for much needed direction, that I am sure I will need!!
The following is what I ordered:
FF:
1 EA 50013 KIT-211239 COMPLETE ROADSTER MK4
KIT TYPE
50013 COMPLETE ROADSTER Mk4
LEFT HAND DRIVE
13083X 302/351W POLY ENG/TRANS. MNTS
TKO/TKX
34158 HYD CLUTCH MSTR CYLINDER KIT
16757X 302 HEADERS w/FAST
14932 SS SIDE EXHAUST SET & MNT HRDW
REAR SUSPENSION
17120 RD IRS w/COMPLETE KIT
16668 IRS 3.55 CENTER & SPINDLES
17237 STANDARD WIDTH SUSPENSION
16038X 31 SPLINE IRS 8.38" DRIVESHAFT
16799 PWR STEERING PARTS (COMPLETE)
16007X VINTAGE GPS GAUGES
16213X BLACK LEATHER SEATS
16613X PWDR FRAME, SATIN BLK
15101 1.50" LEFT CHROME ROLLBAR
15105 1.50" RIGHT CHROME ROLLBAR
17165 IRS WIL BRK KIT - RED 12.88"
15370X 12.88" FRNT WIL BRK RED
16689 17" HALIBRAND WHEEL/TIRE PKG
17137 WOOD STEERING WHEEL
17203X ROADSTER BODY WITH CUT-OUTS
17138 DASH COMPONENTS (VINYL & ALUM)
12049X WIND WING SET
12042X SUN VISOR SET
16808 TRUNK GAS STRUT KIT
12012X OVER-RIDER KIT
15154 MK 4 LOGO FLOORMATS
33862 EFI IN-TANK FUEL SYSTEM
15158XX 1.50" ROLLBAR GROMMET SET
15158X 1.50" ROLLBAR GROMMET SET
16037 IRS FRNT & REAR SWAYBAR PARTS
17063 HEATER/DEFROSTER COMPONENTS
15635 CENTER DASH SUPPORT & PARTS
15659X ASSEMBLED SIDE LOUVER SET
Bluprint:
Item Number Description
347 fuel injected Sniper 2
BP3473CTFK RT52439 for optional 5th gear
BPP302FDPS Kit, Ford Small Block Front Drive Kit
BPPTKX600AB Tremec TKX-600 Transmission
Breese:
PRODUCT Breeze- Mark Reynolds
70810 Gas Pedal Kit, Breeze EzeMount Dogleg with Wilwood style Pedal Pad × 1
70561 Engine Compartment Battery Mounting Kit, Mk3/3.1/4 Roadster × 1
70772 Radiator Fan Shroud for Roadster × 1
35455 Koolmat Insulation Kit for Mk4 Roadster, 14 piece × 1
70779 Hood Scoop Fastener Set with Acorn Nuts × 1
Wedgelock Pliers × 1
Wedgelock Temporary Fastener - 1/8" × 75
Wilwood Remote Brake Balance Bar Adjuster × 1
70752 Cockpit Storage Cubby Kit for Mk4 Roadster × 1
Offset Rack Mounting Kit for FFR Roadster and Coupe × 1
Wedgelock Temporary Fastener - 3/16" × 5
Billet Aluminum Side-View Mirror Set with Polished Finish, Made in USA × 1
70602 Installation Kit for New Steel Frame “Classic” Seats × 1
70781 Power Steering Hose and Fitting Kit for use with Driver Side Mounted Ford Pump × 1
70805 LED Exterior Front Lighting Kit for Mk4 Roadsters that came with Rectangular LED Taillights × 1
70558 Heavy Duty Hinged Radiator/Shroud Mounting Kit × 1
70551 Lower Radiator Support Kit × 1
70753 Dead Pedal Kit × 1
Fuel Filter/Regulator and Single Line Kit for Sniper in Roadster (Direct Mount) × 1
70734 190 LPH In-Tank EFI Fuel Pump with 3/8" Outlet × 1
Radiator Cowl Cover Kit for use with FFR Hinges × 1
Dash Support Bracket Kit × 1
70748 Fuel Line Assembly, EFI Pump to Filter, 3/8" - 3/8" Quick Connect × 1
Metco:
Driveshaft safety loop
Fman liked this post
Awesome choices! You are going to have so much fun! Keep us apprised.
Art Shand, Big Canoe GA
BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
Welcome to the build journey. Building a car was a leap for me too, you'll be surprised how much you'll learn. Have fun!
2022 MKIV BP347, SniperEFI, IRS. Delivered June 22, Engine install Jan 23, first start May 23.
Welcome to the club. You are in for a blast!
Welcome! Enjoy the build, just be carful hanging around here, we love to spend your money.
Congratulations and welcome. You said you are picking it up. Are you from MA or a surrounding state?
Sorry if I mis stated. I am going to have Stewart pick up and deliver it deliver it!! I live in Erie, PA!!
I think when they get here Spring will be in full swing!
Craig
As you can see with my Breese order you have already spent some of my money!!
I see the Erie, Pa in one of your posts but also ad it to your signature. Somewhere along the line location really helps when answering questions. And welcome to a new life that will be a blast.
If you need windshield wipers in your state for registration purposes there is someone on the other forum who is selling a still in the box FFR windshield wiper kit for $250. That is half off.
CraigS
Not sure how to do that. I might be having a senior moment!
The other forum is FFcarsdotcom.
JR
craig6990
What is the other forum?
https://www.ffcars.com/forums/
To add your location and other things go to the top right and click 'Settings'. Now on the left margin under 'My Settings' click 'Edit Profile' and scroll down to 'Location'. Type in whatever you like. Some prefer to just list their state which is fine. See that you can also 'Edit Avatar' which allows you to include a picture like mine w/ the silver FFR w/ hardtop. And 'Edit Signature' like my car details. The details will come in real handy when we try to answer questions later on.
Thank you!
I need to get my privileges increased. How do I do that??
Craig
Just keep posting. I think you can do all the things Craig suggests with 10-20 posts under your belt.
MK IV Roadster #8631
Congratulations! I may have to pick your brain sometime on your selections. That is a great lead time for the delivery so it sounds like things are readily available these days! Looking forward to some inbound pictures!!
Great news!
My kit will be completed on 3/23 and Stewart is delivering it on the 29th! I am like a kid waiting for Christmas! Only 7 more sleeps!! Hard to wait.
craig6990
Great news!
We used to say that as 6 days & a Wake-Up Welcome to the group. Lots of us old farts here so you will fit right in.
craig6990
Great news!
Woooohooooooooooo!!!!!
Congrats and use the forum. Not sure how I would have completed my build without it...
Congratulations!
.....and I was born in Erie. 68 years ago!
