Thanks Thanks:  2
Likes Likes:  4
Results 1 to 25 of 25
Thread: New kid (old person) The journey Begins MK IV 347 EFI
    Nov 2023
    Erie, PA
    Smile New kid (old person) The journey Begins MK IV 347 EFI
    Good afternoon All!!
    Well after lengthy review of the build blogs, I have pulled the trigger and ordered my MK IV kit. I got a call today that it will be available for pickup on March 23rd. Woohee!! Can’t wait to get started! I attended the build school earlier this year (January) and it gave me enough confidence to build the car! I have no experience in “wrenching” but are pretty good at following directions. I will look to the Factory Five Forum for much needed direction, that I am sure I will need!!
    The following is what I ordered:
    FF:
    1 EA 50013 KIT-211239 COMPLETE ROADSTER MK4
    KIT TYPE
    50013 COMPLETE ROADSTER Mk4
    LEFT HAND DRIVE
    13083X 302/351W POLY ENG/TRANS. MNTS
    TKO/TKX
    34158 HYD CLUTCH MSTR CYLINDER KIT
    16757X 302 HEADERS w/FAST
    14932 SS SIDE EXHAUST SET & MNT HRDW
    REAR SUSPENSION
    17120 RD IRS w/COMPLETE KIT
    16668 IRS 3.55 CENTER & SPINDLES
    17237 STANDARD WIDTH SUSPENSION
    16038X 31 SPLINE IRS 8.38" DRIVESHAFT
    16799 PWR STEERING PARTS (COMPLETE)
    16007X VINTAGE GPS GAUGES
    16213X BLACK LEATHER SEATS
    16613X PWDR FRAME, SATIN BLK
    15101 1.50" LEFT CHROME ROLLBAR
    15105 1.50" RIGHT CHROME ROLLBAR
    17165 IRS WIL BRK KIT - RED 12.88"
    15370X 12.88" FRNT WIL BRK RED
    16689 17" HALIBRAND WHEEL/TIRE PKG
    17137 WOOD STEERING WHEEL
    17203X ROADSTER BODY WITH CUT-OUTS
    17138 DASH COMPONENTS (VINYL & ALUM)
    12049X WIND WING SET
    12042X SUN VISOR SET
    16808 TRUNK GAS STRUT KIT
    12012X OVER-RIDER KIT
    15154 MK 4 LOGO FLOORMATS
    33862 EFI IN-TANK FUEL SYSTEM
    15158XX 1.50" ROLLBAR GROMMET SET
    15158X 1.50" ROLLBAR GROMMET SET
    16037 IRS FRNT & REAR SWAYBAR PARTS
    17063 HEATER/DEFROSTER COMPONENTS
    15635 CENTER DASH SUPPORT & PARTS
    15659X ASSEMBLED SIDE LOUVER SET
    Bluprint:
    Item Number Description
    347 fuel injected Sniper 2
    BP3473CTFK RT52439 for optional 5th gear
    BPP302FDPS Kit, Ford Small Block Front Drive Kit
    BPPTKX600AB Tremec TKX-600 Transmission
    Breese:
    PRODUCT Breeze- Mark Reynolds
    70810 Gas Pedal Kit, Breeze EzeMount Dogleg with Wilwood style Pedal Pad × 1
    70561 Engine Compartment Battery Mounting Kit, Mk3/3.1/4 Roadster × 1
    70772 Radiator Fan Shroud for Roadster × 1
    35455 Koolmat Insulation Kit for Mk4 Roadster, 14 piece × 1
    70779 Hood Scoop Fastener Set with Acorn Nuts × 1
    Wedgelock Pliers × 1
    Wedgelock Temporary Fastener - 1/8" × 75
    Wilwood Remote Brake Balance Bar Adjuster × 1
    70752 Cockpit Storage Cubby Kit for Mk4 Roadster × 1
    Offset Rack Mounting Kit for FFR Roadster and Coupe × 1
    Wedgelock Temporary Fastener - 3/16" × 5
    Billet Aluminum Side-View Mirror Set with Polished Finish, Made in USA × 1
    70602 Installation Kit for New Steel Frame “Classic” Seats × 1
    70781 Power Steering Hose and Fitting Kit for use with Driver Side Mounted Ford Pump × 1
    70805 LED Exterior Front Lighting Kit for Mk4 Roadsters that came with Rectangular LED Taillights × 1
    70558 Heavy Duty Hinged Radiator/Shroud Mounting Kit × 1
    70551 Lower Radiator Support Kit × 1
    70753 Dead Pedal Kit × 1
    Fuel Filter/Regulator and Single Line Kit for Sniper in Roadster (Direct Mount) × 1
    70734 190 LPH In-Tank EFI Fuel Pump with 3/8" Outlet × 1
    Radiator Cowl Cover Kit for use with FFR Hinges × 1
    Dash Support Bracket Kit × 1
    70748 Fuel Line Assembly, EFI Pump to Filter, 3/8" - 3/8" Quick Connect × 1
    Metco:
    Driveshaft safety loop
  2. Likes Fman liked this post
    Jul 2021
    Big Canoe, GA
    Awesome choices! You are going to have so much fun! Keep us apprised.
    Art Shand, Big Canoe GA
    BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
    Jan 2021
    Welcome to the build journey. Building a car was a leap for me too, you'll be surprised how much you'll learn. Have fun!
    2022 MKIV BP347, SniperEFI, IRS. Delivered June 22, Engine install Jan 23, first start May 23.
    Sep 2019
    Bothell, WA
    Welcome to the club. You are in for a blast!
    Copperhill, TN
    Welcome! Enjoy the build, just be carful hanging around here, we love to spend your money.
  7. Likes M. Townsend liked this post
  8. #6
    Nov 2018
    CT
    Congratulations and welcome. You said you are picking it up. Are you from MA or a surrounding state?
  9. #7
    Nov 2023
    Erie, PA
    Sorry if I mis stated. I am going to have Stewart pick up and deliver it deliver it!! I live in Erie, PA!!
    I think when they get here Spring will be in full swing!
    Craig
  10. #8
    Nov 2023
    Erie, PA
    As you can see with my Breese order you have already spent some of my money!!
  11. #9
    Nov 2023
    Erie, PA
    Thank You!!
  12. #10
    I see the Erie, Pa in one of your posts but also ad it to your signature. Somewhere along the line location really helps when answering questions. And welcome to a new life that will be a blast.
  13. #11
    Nov 2018
    CT
    If you need windshield wipers in your state for registration purposes there is someone on the other forum who is selling a still in the box FFR windshield wiper kit for $250. That is half off.
  14. #12
    Nov 2023
    Erie, PA
    Not sure how to do that. I might be having a senior moment!
  15. #13
    Nov 2023
    Erie, PA
    What is the other forum?
  16. #14
    Senior Member jrcuz's Avatar
    Stafford Virginia
    The other forum is FFcarsdotcom.
    JR
  17. #15
    Nov 2018
    CT
    Quote Originally Posted by craig6990 View Post
    https://www.ffcars.com/forums/
  18. #16
    To add your location and other things go to the top right and click 'Settings'. Now on the left margin under 'My Settings' click 'Edit Profile' and scroll down to 'Location'. Type in whatever you like. Some prefer to just list their state which is fine. See that you can also 'Edit Avatar' which allows you to include a picture like mine w/ the silver FFR w/ hardtop. And 'Edit Signature' like my car details. The details will come in real handy when we try to answer questions later on.
  19. #17
    Nov 2023
    Erie, PA
    Thank you!
    I need to get my privileges increased. How do I do that??
    Craig
  20. #18
    Jun 2015
    Fairfax Station VA
    Just keep posting. I think you can do all the things Craig suggests with 10-20 posts under your belt.
    MK IV Roadster #8631
  21. #19
    Nov 2023
    Erie, PA
    thanks John!!
  22. #20
    Feb 2024
    Congratulations! I may have to pick your brain sometime on your selections. That is a great lead time for the delivery so it sounds like things are readily available these days! Looking forward to some inbound pictures!!
  23. Thanks craig6990 thanked for this post
  24. #21
    Nov 2023
    Erie, PA
    Great news!
    My kit will be completed on 3/23 and Stewart is delivering it on the 29th! I am like a kid waiting for Christmas! Only 7 more sleeps!! Hard to wait.
  25. Likes rustyrim liked this post
  26. #22
    Raleigh NC, OIB NC
    Great news!
    We used to say that as 6 days & a Wake-Up Welcome to the group. Lots of us old farts here so you will fit right in.
    Kevin
    MKIV #8234
  27. Thanks craig6990 thanked for this post
  28. #23
    Feb 2024
    Great news!
    Woooohooooooooooo!!!!!
  29. #24
    Jun 2022
    Congrats and use the forum. Not sure how I would have completed my build without it...
  30. #25
    Senior Member Jim Wehr's Avatar
    Hamilton, VA
    Congratulations!
    .....and I was born in Erie. 68 years ago!
  31. Likes craig6990 liked this post
