Results 1 to 4 of 4
Thread: Rev Limiter Mk4 Coyote TKX
    Jun 2023
    hi, I just finished my Mk4 build with Coyote crate engine and TKX trans with Ford Control Pack included in the kit.
    I just did my road testing. However, it seems that the rev wont go pass 4.000 mark. its the same when it is in stationary, or in motion. I've inspected the speed sensor located in the gearbox, the wires from the speed sensor goes to the dash. It doesnt go to the ECU. i try to locate the ECU Pin for the speed sensor. can anyboody help with the ECU Pin out or what did I do wrong for this case. The ECU I got is pn RMJR3A-12A650-AKA. Any help will be appreciated.
    I responded to your same post in the Coyote forum area. Factory Five doesn't actively monitor this location. Plus cross posting is discouraged.
    Nov 2021
    Did you get a coyote tune on your engine? If not, that maybe your issue
    Jun 2023
    Quote Originally Posted by Sharris2 View Post
    no i have not done anything yet just done installing everything and do the road test
