Thread: Brake Pressure gauge for setting bias???
    Sep 2022
    Huntington, IN
    Any of y'all use a Brake Pressure gauge for setting brake bias?
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    I have never heard of anyone using a pressure gauge, plan B might be a brake bias adjuster. I am using one it works good and you can adjust easily in the drivers seat.
    https://www.summitracing.com/parts/t...kaAv2iEALw_wcB
    https://www.summitracing.com/parts/til-72-561
    Build #9818 completed 04/2021 - Dart SBF 427, PF4 EFI, TKO600 Build thread: https://thefactoryfiveforum.com/show...utton-head-mod
    Build review video:https://www.youtube.com/watch?v=k6IAbo2sFt4&t=1111s My finished car: https://thefactoryfiveforum.com/atta...7&d=1638415131
    Senior Member F500guy's Avatar
    Aug 2022
    Portland, Oregon
    For that to be valuable information, you would need a brake calculation tool to give the relative front/rear brake force with the tires, just knowing the pressure is not necessarily going to provide the needed information. I in the past have used a disk brake analyzer tool-A pressure device that you insert in-place of the pads to show caliper force which can be tested with the bias adjustment to see how the system responds and give a setup point when one changes brake parts and needs to get back to a certain point.
    MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
    "Build a Car" They Said "It Will Be Fun "
    Nov 2021
    Texas!
    Sounds like something where you perform five layers of measuring and adjusting and, in the end, adjust the bias to suit how the car handles.
    If you want to learn the bias pressures and all that for the fun of it, it's worth doing.
    Rob Windsor
