Thanks Thanks:  2
Likes Likes:  4
Results 1 to 10 of 10
Thread: Fun time on the dyno and also my dumb mistake....
    Senior Member john42's Avatar
    Aug 2020
    Hollis, NH
    First the good news! Had a very good dyno session and got the new Boss 347 w/ Sniper 2 running really nice. Still some fine adjustments to do but it is SOOOOOOO much better now.
    And the bad news... While on the dyno... something that I was warned about... when we (Traveling builder) put the new engine in Mark told me to trim the body around the right side exhaust. I 100% intended to do it soon(tm)... I just had not and that became a hard lesson as it caught fire!
    Well it's trimmed now... Anyway... when a very smart person like Mark says you should do something..
    MK3 Challenge Car, Boss 347, Sniper 2 EFI
  2. Thanks rpard508, JJK thanked for this post
    Likes FF33rod, Geoff H liked this post
    Jul 2022
    DFW Texas
    very cool. for reference, how much of a gap was there between the body and side pipe? The body caught fire?
    Aug 2020
    Hollis, NH
    Quote Originally Posted by JJK View Post
    It was touching. Yes it caught on fire.
    Jul 2022
    DFW Texas
    any idea on the minimum safe gap? I am sitting at about 1/16" and now concerned.
    Nov 2019
    Charlottesville VA area
    Just curious. What were the hp/torque before and after?
    Vince
    Aug 2020
    Hollis, NH
    Don't take my word for it but after this experience I would think almost any visible gab would be enough. The lengths that it took to, to actually catch fire was. #1 the body was touching the exhaust for a length of about 2 inches. #2 running on the dyno had zero airflow on the exhaust as the fans were pushing air into the front of the car. #3 running at 5000-6000 rpm long enough that the exhaust was beginning to turn a faint pink. Real world conditions those 3 will never all be true at the same time. After it occurred we put fans on the sides blowing air across the exhaust and had no further issues. I cut/clearanced the exhaust yesterday (2 days after the dyno day).
    Aug 2020
    Hollis, NH
    Quote Originally Posted by vtullomk4 View Post
    Vince
    Well we're still working on it. I'm going back in a couple weeks.
    Started at about 280tq/270hp (to the wheels). which is... lol. ouch
    Things that have been adjusted/fixed:
    Timing was 5 degrees off
    lots of fuel map changes
    was running +25% rich
    throttle would only go to 60% of full, with some adjustment we got it to 80%
    Then we got to:
    390tq/376hp
    Things that I am fixing now:
    Sniper is still getting confused with the wrong spark plugs. The plugs in it now are for a Carb setup and aren't resister type. I've purchased a set of NGK resister type. The plugs were confusing the heck out of the Sniper 2 causing misfires, rough idle and stalling when returning to idle.
    I've also redone the linkage on the sniper 2 and now have full use of the throttle to WOT (100%).
    I've been very pleased with Randy @ Horsepower Farm in NH. It took him about 2 minutes to find the spark plug issue. He found the spark plug issue by just hearing the car running for a few minutes. Was amazed it how quickly he could look at the log on the computer and walk over to the car and point at exactly what the issue was. He was also a big fan of Factory Five and they've built a few in their shop.
    Best guess (hope) now going back in a couple of weeks with correct plugs and a throttle that actually goes to WOT is to see 410tw/400hp. To the crank this motor is supposed to be 480tq/470hp.
  9. Likes Railroad, FF33rod liked this post
  10. #8
    Jun 2018
    North Vancouver, BC, Canada
    Love it, except for the fire part Out of curiousity what's the details on the 347? manifold, heads, compression, cam...
    Gen 1 '33 Hot Rod #1104
  11. #9
    Aug 2020
    Hollis, NH
    Was back at Horsepower farm this weekend for a Dyno showdown and also helping me out with getting my Sniper2 dialed in. We "found" another 50(ish) horsepower and got it idling right!
    Skip to 27:00 for.... Cobra goodness...
  12. #10
    Aug 2020
    Hollis, NH
    Dyno vid...
