Likes Likes:  3
Results 1 to 23 of 23
Thread: Making your own oil cooler and brake duct grilles.
    For my fellow Roadster builders who are on a budget, or just like to make things themselves, here is what I did. Cheap and simple.
    Go to a commercial kitchen supply store, and purchase a "large" crispy pizza crust pan. They are made of extruded aluminum, and should cost less than $10. Who knows, you may even be able to purchase one cheaper at Wal-mart if they sell them.
    I did this while my body was still off the car, but by simple measuring it could still be done with the body on. I held the pizza pan up to the back of the openings, and traced them with a marker. Then allowing for some extra material, I cut out the pieces. After that I held the pieces behind their respective openings, and using only my fingers, I squeezed them in to a shape that conformed with the opening. You may first want to make a few relief cuts along the edge to help do this. Your kind of molding them enough to wrap around the rear of the opening..if you get what I mean..lol
    In my case, I allowed for the quickjack body bolts to help retain them, by cutting two holes on one side of the grilles, for the bolts to pass through. Silicone the other areas at the back for additional retention. Some fellows just use silicone by itself, and don't bother with the body bolts. and I will probably do just that, for the oil cooler grille, as I can't see any other easy way to fasten it.
  2. Likes seb liked this post
    Fort Lauderdale Fl.
    Perfect!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Senior Member NicksPapaw's Avatar
    Knoxville TN
    Great job Bill. This can also be done using a gutter guard found at your local HD or Lowes. Doesn't always have to cost a bunch to work correctly.
    MK 3.1 #6422, Complete Kit, 340hp Ford Racing Crate Engine, WC T-5 Trans, 3.55 Rear, Barcelona Red Mica Metallic, Silver Stripes
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Yet another reason I love this site - such great ideas from all the builders. Keep 'em coming!!!
    Later,
    Mk3.1 #7074
    Senior Member NICK C's Avatar
    Lawton, Oklahoma
    Thanks Bill. Too cool.
    Sep 2011
    Tampa Fl
    Bill, great job on the grill's. BTW Necessity is the mother of invention!!
    Fayetteville WV
    That is slick way to fix a grille. Nice!
    1972 Corvette Stingray 350 c.i. Manual Steering & Brakes
    2003 H-D Softail Deuce 88 c.i. TwinCam
    Gen 3 Coupe Dreamer
    Aug 2012
    POWAY CALIF.
    Talk about timing. This weekend three of us were talking about this very same subject.
    I have some leftover SS mesh from Pegasus that I used for a radiator stone guard. I
    will give that a try, but the pizza pan idea is a good alternative. Thanks for the BUMP Bill.
    Mack
  10. #9
    Raleigh NC, OIB NC
    FWIW mine are held in with GE silicone from Home Depot. Still tight after 22 months.
    Kevin
    MKIV #8234
  11. #10
    San Diego Ca 92106
    Wondering if this material would work?
    https://www.walmart.com/ip/46059475
  12. #11
    That should work fine. Might be a little harder to bend back, but just cut a few more reliefs in it, (or darts as women would call them when working on a dress material).
    You could use a hammer and a piece of pipe, to form the rounded ends easier.
  13. #12
    Senior Member canuck1's Avatar
    Victoria, BC CANADA
    MMM... pizza! This thread is making me hungry!
    Sean
    MK 3.5 roadster (MK IV body retrofit to MK III chassis) 396W stroker, 4 bbl mass air EFI, QH (self-tuned), AFR 195CC Renegade, XE274HR, GP 4-1-4 SS headers, 3link, 3.73, 15" Halibrand replicas, SAI mod, bumpers, 2 X roll bars, I² electronics, PS, hydroboosted brakes: 95 GT front, custom MK VIII calipers/Cobra discs rear, FFR front, Levy rear LCA's, Forte front, VPM rear bars, CF dash, mod comp layout w/Auto Meter Ultra-Lites, Lucas tri-bar headlights, coupe taillights, painted by SRP (again!)
  14. #13
    Senior Member jakester888's Avatar
    Portland, OR
    Quote Originally Posted by AC Bill View Post
    I don't want to go through the quick-jack bolts - and I'm not as confident that Silicone would make a good bond between fiberglass and aluminum. Is there a special fiberglass/metal bonding glue I can buy?
  15. #14
    There are several epoxy glues available that would work with both materials. Gorilla glue for example.
    Could be difficult to remove afterward, if you ever needed to, as that stuff really sticks.
    Several builders have used silicone for this purpose, (and fo holding the FFR fender vents in place), and somewhat surprisingly, it seems to hold better than one would think.
  16. #15
    Woodstock ,Illinois
    Silicone works just fine!
  17. #16
    A bump up for new builders..
  18. Thanks David Hodgkins thanked for this post
    Likes Kmcallahan liked this post
  19. #17
    Raleigh NC, OIB NC
    Will update this. 5+ years on the road @ 12,000+ miles & the GE silicone is still holding fast even with a cold air duct on the oil cooler vent.
    Kevin
    MKIV #8234
  20. #18
    Jax Beach, FL
    Nice.
    As long as there are no anchovies.
  21. #19
    May 2022
    Fishers, Indiana
    Does FFR sell,larger pieces of the material that they sell for the air ducts that can be used to make the grill insert
  22. #20
    Raleigh NC, OIB NC
    Thread back from the dead. Will add my screens are still on after almost 9 years with silicone. Radiator shield is a dirt track Nomex piece cut to fit & sprayed flat black with outdoor grill paint.
    Kevin
    MKIV #8234
  23. Likes maclonchas liked this post
  24. #21
    Kevin have you noticed any change in running temps since adding the Nomex?
    I've been lucky so far, as far as rad damage from road debris, but I shudder whenever a dump truck, or low deck, hauling an excavator pulls in front of me. Nomex would be a simple solution.
  25. #22
    Prescott, AZ
    I used the Ultra Black gasket maker to adhere the grills, just like silicone but sticks even better.
    As for the grill material, I used expanded SS purchased from Online Metals. I wanted SS for the corrosion resistance. As large piece of the expanded SS was used to make a radiator protector. I used screen door trim to make a protective edge for the protector and then used the industrial Velcro to adhere it as I wanted the protector removable.
    Just another way to approach making these parts.
  26. #23
    May 2022
    Fishers, Indiana
    I sent a request to FFR to see if I could purchase a large piece of the air duct mesh for the front grill. They have not responded . Does anyone know where to purchase the mesh and what are the specs. As always disappointed in the lack of response from FFR
