Thread: Trunk Aluminum
    Senior Member NICK C's Avatar
    Lawton, Oklahoma
    Trunk Aluminum
    I have MKIV 7622 and am ready for trunk aluminum to go in. The manuel shows a separate piece over the fuel pump at a higher level than the floor over the sending unit. But my aluminum is one piece all the way across. Seems like I'm loosing tunk space that way. In any event do I have the wrong aluminum pieces? Thanks.
    Colorado Springs
    That's the way my MII is/was - one flat panel across the entire width. I didn't know the MIV had changed that in any way.
    In any case, yes, you are losing a lot of trunk space. if you're going to use a fuel cell, that area beneath the trunk floor will be filled. But if you're using a donor fuel tank, that space is empty.
    Lots of people have modified their trunk floors to use that space. Cobra Earl has a very nice kit to help you do that. I started with his kit and then made some slight mods to improve it for my use. I'm sure others will share their solutions here.
    I have plenty of trunk space for my wife and I to pack everything we need for a week long road trip. Including convertable top, tools, etc.
    .boB "Iron Man"
    www.RacingTheExocet.com
    The early Mk4 I built had the dropped trunk floor:
    Shortly after production began FFR went back to the higher, flat floor with triangulated bracing as was used on Mk3 and earlier cars. As Bob mentions Cobraearl makes a trunk box to capitalize on the dead space above the fuel tank. His version has the builder cut the trianglating tubing out. On my Mk3 I constructed my own but left the tubing in place.
    I can still fit two helmets into the open triangles and all sorts of soft stuff around 'em. One of the best mods I did.
    Lawton, Oklahoma
    Looks good. I'll check out his site. He has other things I've purchased. Thanks Nick
    Senior Member E-Ticket Ride's Avatar
    Huntington Beach, California
    Here is a link to one I'm installing from Dark Water Customs:
    http://www.darkwatercustoms.com/cart...product=474076
    Separate boxes within 2 of the triangle spaces, including a cover. Doesn't look as large as the other, but just another idea.
    CL
    Confidence: The feeling you have before you truly understand the situation. FFR 7652 Mk IV Base Kit w/IRS: ordered 10/19/2011; Arrived 11/19/2011. Coyote, Trans & headers Installed 9/11/17. First Start 12/19/17, First Go-cart 3/2/18. Aligned and go-karting. Working the interior now. Happy customer of FFR, North RaceCars, Forte's, and Breeze.
    Chris Lewis
    Lawton, Oklahoma
    Thanks E-ticket. I like the glove box also since my heater is in the place for a normal glove box. I'll see if I get a response from Cobra Earl as I e-mailed him about his trunk mod. Thanks again.
    Super Moderator
    Ray's Avatar
    La Mesa, California
    trunk box2.jpgtrunk box1.jpg I did my own (back before there were any vendors making a kit.)
    Just cut the factory trunk floor and have left the boxes open.
    Ray
