I finally got the heater hoses installed correctly, and solved the over heating problem that I was having. It wasn't hard to do, but when I intalled it initially, I had the hose running from the water pmp, and the hose running from the overflow tank crossed. I had already filled it with coolant, and burped the lines. So I was really dreading the thought of disconnecting the hoses, draining the coolant back out, switching the connections, and going through the process of refilling the system again.
But I had the perfect reason to get outside and get it done... My house was full of loud women who were here for my daughter's bridal shower, drinking wine, and getting even louder... It was time to get the heck out of there.
Once I got under the car and started working, it wasn't so bad. Of course I did get a face full of engine coolant, as I disconnected the hoses and tried to aim for the drain pan. But I knew that it was coming, so I made my peace with it, and got busy. 45 minutes later, it was done. I started the engine up and let it idol for 15 or 20 minutes. Problem Solved! Woo Hoo. Thanks to Mike Holland (Crash) for making the heater valve kit available to us. Works like a champ when installed correctly.
Before, if I let it idol between 5 to 7 minutes, the engine would get up to 210 / 220 if I let it. Now it hits 185 / 195, and kicks on the fans, and holds a steady temp. I finally feel comfortable enough to put the firewall and window back in, tidy up the wiring bundles, and install the bottom panels and skid kit. Then I'll install the seats, wire the gauges, and it will finally be ready for the interior.
There is a finally finish line in my somewhat near future. I may actually get to drive this thing legally this summer! What a concept!
