Results 1 to 2 of 2
Thread: Mark II IRS PS/PB 347 Roadster
    Cobra Driver UpstateCobraGuy's Avatar
    East Greenbush, NY
    This FFR Mark II 347 powered IRS Roadster is complete and ready to be enjoyed. Featuring authentic classic looks of vintage 1964 Ford Guardsman Blue / Wimbledon White Stripes, with a modern stroked Ford small block producing 400 rear wheel horsepower, yet features the comfort of power steering and brakes. This is a high end build and would cost over $45,000 to reproduce today.
    Engine:
    -Ford H/O block stoked to 347 CID 400 RWHP
    -AFR 185 heads (dyno time was spent selecting best valve spring, titanium retainers added at last tune)
    -Holley 650 cfm double pumper carburetor
    -Edelbrock Victor Jr. manifold
    -Comp Cams extreme energy roller cam
    -Comp roller lifters
    -Comp 1.6 roller rockers
    -Scat steel crank
    -Scat H-beam rods
    -Probe dish racing forged pistons
    -Pioneer harmonic balancer
    -Melling oil pump
    -Canton 7qt. "T" oil pan
    -Canton main support girdle with windage tray
    -ARP internal fasteners
    -Energy Suspension polyurethane engine and transmission mounts
    -Factory Five 4 into 4 ceramic coated headers
    -Gas-N Performance Products stainless steel side pipes
    Drivetrain
    -Tremec T5 5 speed manual transmission
    -Ford 8.8 inch Traction-loc limited slip IRS rear differential
    -3.27 gear ratio
    Cooling
    -Ford Racing water pump (FMS-M-8501-C50)
    -Factory Five Racing (Afco) dual core aluminum radiator
    -Breeze Automotive lower radiator support and aluminum fan shroud
    -Moroso overflow tank
    -Electric fan with automatic on/off
    Electrical
    -MSD distributor
    -MSD ignition box and coil
    -Ford 95 amp alternator
    -Custom rear mounted battery
    Suspension
    -Factory Five front tubular lower control arms, fully adjustable upper control arms
    -Power steering with Heidts adjustable power steering valve
    -Factory Five IRS / Independent rear suspension with upper and lower tubular control arms
    -QA-1 coil over racing shocks
    Brakes
    -Four wheel power disc brakes (Mustang GT 11” fronts, Thunderbird SC 10.5” rears)
    -1993 Ford Mustang Cobra Master Cylinder
    -Braided steel brake lines
    -Wilwood adjustable proportioning valve in rear line
    Wheels and Tires
    -Team III Halibrand replica wheels with BFGoodrich T/A tires
    -Front P235/60R 15
    -Rear P275/50R 15
    Safety / Interior
    -Simpson 3 inch 5 point harnesses
    -427 “Street” dashboard layout with Autometer Vintage gauges (reverse speedo) and glove box
    -Original styled “VW” column mounted turn signal
    -14” Leather wrapped steering wheel with proper ****** Cobra emblem
    -Black Bentley automotive carpet
    -A/C brake and clutch pedal covers
    -Factory Five floor mats
    Exterior
    -New 2 stage 1964 Ford Guardsman Blue with Wimbledon White Stripes paint
    -Authentic radiator aluminum panel
    -Black quick jacks per CSX 3034
    -Finshline sourced ****** Cobra hood and decklid emblems
    -”Powered by Ford” side emblems
    -Lowered 2” chrome plated roller bar
    Car is sold
    Mark III 4630RD Explorer 302, Holley SA570, FRPP B-cam, 4 to 4's, 3 Link, Bullitt wheels, Baer Brakes, 3.73 gears, HD T-5, I2 wiring, Koni Coilovers, Classic Gauges. Jaguar Racing Green w/ Silver stripes
    PM me if you live in Upstate New York. Get added to the "Upstate Cobras" email list. 60+ members!
    East Greenbush, NY
    Car is Sold
