Thread: Coyote Header Help. Is this fitment correct?
    Senior Member ClemsonS197's Avatar
    Marietta, GA
    So I got my FFR Coyote shorty headers. Got them bolted up and there is almost no room to connect a J-pipe. And I have the Whitby spacers raising the block. There looks to be ~1.5" between the header and the 4" main tube.
    And about half the outlet is over the main tube as well.
    I took out the 302 j-pipes I had laying around just to see how close it is. It looks like I need at least and 1" more clearance to get them to fit. Dropping the trans mount would create interference with the driveshaft. Drivers side looks like the exact same issues.
    MK3.1 #7076 - Under Construction....
    Coyote 5.0/Solid 8.8/Tremec 3650
    How to:
    Coyote Power Steering
    05-09 T3650 in a Roadster
    Best bet is to call FFR directly and talk to Jesper or Brian Z. Most likely, you have the first set out the door so there will be some teething issues.
    Mark Twain
    WOW!! That's not even close!
    Tech Support, FFR Brian Z's Avatar
    Wareham MA
    That is the way they are supposed to fit. The new adapter pipes will fit no problem according to Jesper.
    Brian Zakrzewski
    FFR Tech & Sales
    Marietta, GA
    Quote Originally Posted by Brian Z View Post
    Wow. Well, I'll bolt them in and see what happens when the adapters become available. Thanks.
    How to:
    Senior Member Slider's Avatar
    Aug 2011
    Fargo, ND
    Has FF figured this out yet?
    Marietta, GA
    Quote Originally Posted by Slider View Post
    That fitment is correct. If you want this set of headers for cheap, see here:
    http://thefactoryfiveforum.com/showt...-or-33-Headers
    How to:
