Power Steering Installation- UniSteer ElectraSteer
Hello All,
In an effort to put forth more information and make it easier to find, I'm going to post this up and use it in the Wiki for all use.
Installing the Unisteer Electra Steer kit
Let's get started:
Here is the kit from Unisteer:
If you're going to order the unit from FFR, then you'll get the needed U-Joints along with it. If you don't you'll need to order 2-U-Joint 9/16 -30 x 3/4" DD found here U-Joint 9/16-30-3/4" DD
