Likes Likes:  6
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 41 to 80 of 252
Thread: Factory Five Roadster Registry
    Factory Five Roadster Registry Entry
    FFR Number
    FFR1153
    Delivery Date
    11 September 1999
    Completion Date
    11 April 2000
    ''Mark''
    TheFactoryFiveForum.com user name of current owner
    Orange One
    Current Owner Name
    Larry Cornish
    Former Owner Names
    State of Completion When Bought
    New Kit from Factory Five
    Color - Body
    Tangelo Pearl
    Color - Stripe
    Pearl White
    Engine Displacement
    302
    Engine Induction
    Injection
    ''Other'' Engine Displacement
    Transmission
    T5
    ''Other'' Transmission
    Rear Gear Ratio
    3.73
    ''Other'' Gear Ratio
    Differential Type
    Tru-Trac
    ''Other'' Differential Type
    Rear Suspension Type
    IRS
    Shocks
    Carrera
    ''Other'' Shocks
    Suspension ''Width''
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    275
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Power Brakes
    • Overriders
    • Custom Mirrors
    • Custom dash
    • Wind Wings
    Regional Location of Build
    NorCal US
    Detailed Description of Custom features
    Image Attachments
    Member cChrisM's Avatar
    Ramsey, NJ
    FFR Number
    F5R1007011
    Delivery Date
    20 July 2009
    Completion Date
    ''Mark''
    cChrisM
    Current Owner Name
    Chris Medlicott
    Former Owner Names
    Color - Body
    Gel Coat
    Color - Stripe
    Engine Displacement
    4.6 DOHC
    Engine Induction
    SuperCharged
    Transmission
    T56
    upgrade to 26 spline input shaft
    Rear Gear Ratio
    3.55
    Differential Type
    Tru-Trac
    IRS
    Shocks
    Koni Single Adjustible
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Power Steering
    • Power Brakes
    • iPOD/MP3 Player
    • SAI Mod
    • Heater
    • Foot Box Vents
    • Drop Butt Mod
    • Trunk Box
    • Trunk Battery Box
    • Backup Light
    • Glove Box
    • Wipers
    • Custom dash
    • Wind Wings
    • Sun Visors
    Northeast US
    Mods:
    Donor: 2003 Mustang Cobra Terminator with 25k miles on the engine
    Notched Front 4" tube for crank clearance
    Champ Oil Pan with baffles
    Canton Windage Tray
    T56 6 speed upgraded with 26 spline input shaft
    McLeod RXT twin disc clutch, resurfaced stock aluminum flywheel by McLeod, McLeod throw out bearing sleeve, Ford Racing pilot bearing & throw out bearing
    Dual Roll bars, shortened and tilted, added cross bar for seat belts
    LED - Third Brake Light, Driving Light and Directions in Roll Bars
    LED - Tail Lights with rectangular tail lights modified to have both top and bottom light flash and brake at the same time
    Wire Harness Diet by Art at WireDiet
    Cruise Control with hidden controls in transmission tunnel
    MGW shifter
    Breeze solid offset bushings for donor steering rack
    Tangent light kit for oil cooler opening
    Custom Heat Exchanger dual pass
    FFR Radiator
    Aluminum tanks for radiator overflow, power steering, heat exchanger
    Trunk cross bars lowered and used first edition MKIV trunk aluminum for larger storage area
    Fore Billet Fuel hat using stock dual pumps, 40 amp Boost-A-Pump, returnless fuel system with -6AN fuel and -8AN air return
    Firewall forward, with wiper motor and heater behind firewall
    Drivers foot box dead pedal bump out, moved tubing to corner for more room
    Passenger foot box expanded, did not keep any of the original panels on this side
    Cut square tube in each footbox to create ramp to lowered floor
    Installed steel under Cobra highback seat (w heaters on sliders) for four bolt mounting
    Russ Thompson Gas Pedal with Mustang billet matching pedals and dead pedal
    Russ Thompson turn signal
    Autometer Ultra-Lite gauges including Air/Fuel and Boost Gauges
    Donor Cobra 13" front brakes and 11.5" rear brakes, using 31 spline half shafts (upgraded longer units)
    ABS, Hydro boost, Power Steering, Power Brakes, Traction Control
    Custom Dash with reinforced grab bar, glove box
    Image Attachments
    Member dforthof's Avatar
    DETROIT CITY
    FFR Number
    F5R1008131RD
    Delivery Date
    17 August 2013
    Completion Date
    ''Mark''
    4
    dforthof
    Current Owner Name
    Dan Forthoffer
    Former Owner Names
    Color - Body
    Silver
    Color - Stripe
    none
    Engine Displacement
    5.0 Coyote
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    335
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Power Steering
    • iPOD/MP3 Player
    • Heater
    • Foot Box Vents
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Front Splitter
    • Glove Box
    • Wipers
    • Custom dash
    • Wind Wings
    • Sun Visors
    Northeast US
    Image Attachments
    FFR Number
    2772
    Delivery Date
    1 January 2001
    Completion Date
    1 January 2002
    ''Mark''
    beachcobra
    Current Owner Name
    Jim Pearson
    Former Owner Names
    Doug Huey
    Car Was Complete
    Color - Body
    Torch Red
    Color - Stripe
    Arctic White
    Engine Displacement
    302
    Engine Induction
    Injection
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Open
    4-Link
    Shocks
    Other
    ''Other'' Shocks
    QA1
    Standard
    Wheel Size
    15''
    Tire Size - Front
    220
    Tire Size - Rear
    245
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Foot Box Vents
    • Trunk Box
    • Trunk Battery Box
    • Overriders
    • Wind Wings
    • Sun Visors
    Southeast US
    Image Attachments
    Senior Member ClemsonS197's Avatar
    Marietta, GA
    FFR Number
    F5R1007076RD
    Delivery Date
    20 November 2010
    Completion Date
    ''Mark''
    3.1
    ClemsonS197
    Current Owner Name
    Kevin Finlay
    Former Owner Names
    Partially Built (Not the Original Purchaser)
    Color - Body
    Unpainted
    Color - Stripe
    Engine Displacement
    5.0 Coyote
    Engine Induction
    Injection
    Transmission
    Other
    TR3650
    Rear Gear Ratio
    3.55
    Differential Type
    Tru-Trac
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Power Steering
    • Power Brakes
    • iPOD/MP3 Player
    • Heater
    • Foot Box Vents
    • Trunk Box
    • Custom dash
    • Wind Wings
    • Sun Visors
    Southeast US
    Donor Coyote out of a 2012 Mustang GT. 2007 Tremec 3650 5-speed transmission with OEM hydraulic clutch. Kirkey Pro-Drag seats.
    Image Attachments
    Member bsnyder's Avatar
    Spanaway WA
    FFR Number
    6836
    Delivery Date
    8 December 2008
    Completion Date
    15 July 2010
    ''Mark''
    3.1
    bsnyder
    Current Owner Name
    Bruce Snyder
    Former Owner Names
    None
    Color - Body
    Indigo Ink blue Pearl
    Color - Stripe
    Star Fire White Pearl
    Engine Displacement
    306
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    255
    Tire Size - Rear
    315
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Heater
    • Trunk Battery Box
    • Overriders
    • Custom Mirrors
    • Wipers
    • Wind Wings
    • Sun Visors
    Northwest US
    Image Attachments
    Clio, MI
    FFR Number
    FFR3489K
    Delivery Date
    20 April 2002
    Completion Date
    20 May 2003
    ''Mark''
    Scott Shumaker
    Current Owner Name
    Scott Shumaker
    Former Owner Names
    Color - Body
    Magnetic Red
    Color - Stripe
    Galaxy Silver
    Engine Displacement
    Other
    Engine Induction
    SuperCharged
    372w
    Transmission
    Other
    Tremec 3550
    Rear Gear Ratio
    3.27
    Differential Type
    Limited Slip
    3-Link
    Shocks
    Other
    ''Other'' Shocks
    QA-1 front, Pro shocks rear
    Standard
    Wheel Size
    15''
    Tire Size - Front
    245
    Tire Size - Rear
    295
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Sun Visors
    Northern Central US
    Image Attachments
    Member otto halstead's Avatar
    FFR Number
    FFR5179K
    Delivery Date
    24 May 2004
    Completion Date
    ''Mark''
    Otto Halstead
    Current Owner Name
    Former Owner Names
    Color - Body
    Redfire Pearl Metallic. G2
    Color - Stripe
    White with pin stripes
    Engine Displacement
    306
    Engine Induction
    Injection
    Transmission
    Other
    AOD
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    275
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Radio
    • Foot Box Vents
    • Trunk Battery Box
    • Wipers
    • Wind Wings
    • Sun Visors
    Southeast US
    Image Attachments
    Knoxville, TN
    FFR Number
    FFR4301SP
    Delivery Date
    12 February 2012
    Completion Date
    ''Mark''
    Tuck60
    Current Owner Name
    Michael Tuck
    Former Owner Names
    Ed Boothman
    Car Was Complete
    Color - Body
    Wimbleton White
    Color - Stripe
    Black/white checkered
    Engine Displacement
    302
    Engine Induction
    Injection
    Transmission
    TKO 500
    Rear Gear Ratio
    3.27
    Differential Type
    Tru-Trac
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    255
    Tire Size - Rear
    255
    Roll Bar Type
    Single Span
    Optional Equipment
    • Power Steering
    • Front Splitter
    Southeast US
    Challenge Car
    Image Attachments
    2bking's Avatar
    Garland, Texas
    FFR Number
    F5R1008127RD
    Delivery Date
    11 September 2013
    Completion Date
    January 2016
    ''Mark''
    4
    2BKING
    Current Owner Name
    King Burgess
    Former Owner Names
    Color - Body
    Ford Crystal Red
    Color - Stripe
    Ghost Crystal Red
    Engine Displacement
    5.0 Coyote
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Torson
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Power Steering
    • Heater
    • AC
    • Trunk Box
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Backup Light
    • Wipers
    • Custom dash
    • Wind Wings
    • Sun Visors
    Texas US
    • Tilt Front
    • Passenger and driver side foot box mods to increase foot room and access to headers
    • Trunk floor lowered
    • Optima battery side mounted in trunk
    • ISIS wiring
    • Parking brake relocated to top of transmission tunnel
    • SS heat shields on engine side of foot boxes
    • Lizard Skin thermal and sound insulation on interior surfaces
    • Carpet in trunk
    • Gas struts for trunk lid
    • Hex cell Polyester radiator screen
    • Russ Thompson turn signal steering column
    • Hydraulic clutch
    • SS 4:1:4 headers
    • Mid shifter on transmission
    • 3 channel ABS
    Image Attachments
    Member TMScrogins's Avatar
    Rescue, CA
    FFR Number
    F5R1008182RD
    Delivery Date
    26 October 2013
    Completion Date
    ''Mark''
    4
    TMScrogins
    Current Owner Name
    Trevor Scrogins
    Former Owner Names
    Color - Body
    Mercedes Brilliant Silver Metallic
    Color - Stripe
    Mercedes Onyx Gray Mica
    Engine Displacement
    5.0 Coyote
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Torson
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    285
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Trunk Battery Box
    • Backup Light
    • Glove Box
    • Wipers
    • Wind Wings
    NorCal US
    Image Attachments
    Member stroked 6t5's Avatar
    FFR Number
    F5R1007568RD
    Delivery Date
    11 September 2011
    Completion Date
    ''Mark''
    4
    stroked 6t5
    Current Owner Name
    Andy Chapelle
    Former Owner Names
    N/A
    Color - Body
    PPG Vibrant Nutmeg
    Color - Stripe
    black
    Engine Displacement
    5.0 Coyote
    Engine Induction
    Stack Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.73
    Differential Type
    Tru-Trac
    IRS
    Shocks
    Koni Double Adjustible
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Foot Box Vents
    • Bumper - Front
    • Bumper - Rear
    • Backup Light
    • Custom Mirrors
    • Custom dash
    Western Canada
    Image Attachments
    Mar 2013
    FFR Number
    F5R1008054RD
    Delivery Date
    4 April 2013
    Completion Date
    7 July 2014
    ''Mark''
    4
    tomnt
    Current Owner Name
    Thomas Tinsman
    Former Owner Names
    Color - Body
    Candy Apple Red
    Engine Displacement
    331
    Engine Induction
    Injection
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Wind Wings
    • Sun Visors
    Texas US
    First 1/4 mile pass 12.20 @ 110.80
    http://s620.photobucket.com/user/tom...b63fa.jpg.html
    Image Attachments
    Freeland / MD
    FFR Number
    7589
    Delivery Date
    25 August 2011
    Completion Date
    25 September 2013
    ''Mark''
    4
    pjdavis
    Current Owner Name
    PJ Davis
    Former Owner Names
    Color - Body
    Audi Brilliant Red
    Color - Stripe
    Audi White
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Power Steering
    • Heater
    • Foot Box Vents
    • Trunk Box
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Custom Mirrors
    • Glove Box
    • Wipers
    • Custom dash
    • Wind Wings
    Southeast US
    Image Attachments
    Hans944 Hans944's Avatar
    Leonardtown, Maryland
    FFR Number
    FFR2574K
    Delivery Date
    25 September 2013
    Completion Date
    1 September 2002
    ''Mark''
    Hans944
    Current Owner Name
    Hans Welch
    Former Owner Names
    Mike Aloisio
    Ray Demayo (Original builder)
    Car Was Complete
    Color - Body
    Red
    Color - Stripe
    Gold
    Engine Displacement
    302
    Engine Induction
    Injection
    Transmission
    T5
    Rear Gear Ratio
    3.73
    Differential Type
    Tru-Trac
    8.8 Currie, Posi Traction
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    245
    Tire Size - Rear
    295
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Radio
    • Trunk Box
    • Bumper - Rear
    • Overriders
    • Backup Light
    • Custom Mirrors
    • Wind Wings
    • Sun Visors
    Northeast US
    * Currie 8.8 Posi Traction/ Trak Loc rear end
    * 4 Wheel manual disc brakes (non power)
    * Oil Cooler
    * Compomotive Halibrand style wheels with B F Goodrich radial T/A tires
    * Ceramic coated header sidepipes
    * SW gauges
    * MGW Ltd "Short Stick" shifter/gear stick
    * Chrome drivers side, single loop roll bar
    * AC Pedals
    * Original replica style wooden trimmed steering wheel
    * Beige Interior
    * Battery relocated into engine compartment
    * Simpson seat belts
    * Big radiator with electric fan
    * Ford Racing 5.0 /302 Crate Motor 340 Horsepower
    *GT 40 Heads
    *GT 40 Intake
    * Full MSD ignition system
    * Cold Air intake cone air filter
    * Center Force Clutch
    * Horsepower is estimated at 380 to 400 HP
    It DOES NOT have:
    * no convertible top
    * no windshield wipers
    * no heater or AC
    * no power steering or power brakes
    It is registered in the State of Maryland as a 1965 Ford/ Street Rod license plates/ no inspection was required to license the vehicle.
    Image Attachments
    South Jordan, Utah
    FFR Number
    5334
    Delivery Date
    April 2003
    Completion Date
    July 2006
    ''Mark''
    1 body 2 frame
    Roy
    Current Owner Name
    Roy Gregerson
    Burnt up car
    Color - Body
    Storm Cloud Metalic Grey (Toyota)
    Color - Stripe
    Black no additive
    Engine Displacement
    302
    Engine Induction
    Injection
    Transmission
    T5
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    4-Link
    Shocks
    Pro-Shocks
    Stock Fox body width
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    275
    Roll Bar Type
    Double painted Hoop
    Optional Equipment•Heater
    •Trunk Battery Box lid
    •Wipers
    •Wind Wings
    •Sun Visors
    *Custom top
    Western US
    Image Attachments
    Mar 2014
    FFR Number
    FFR7541
    Delivery Date
    10 April 2011
    Completion Date
    8 April 2012
    ''Mark''
    4
    spitfun
    Current Owner Name
    Rich Torres
    Former Owner Names
    Dave Nocito,Zane Sterrett
    Car Was Complete
    Color - Body
    Lexus Indigo Blue
    Color - Stripe
    Viper Sliver
    Engine Displacement
    4.6 DOHC
    Engine Induction
    SuperCharged
    Transmission
    Other
    Tremec 3650
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Radio
    • iPOD/MP3 Player
    • SAI Mod
    • Heater
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Glove Box
    • Wind Wings
    • Sun Visors
    Northeast US
    Image Attachments
    Cobra Driver UpstateCobraGuy's Avatar
    East Greenbush, NY
    FFR Number
    F5R1004630RD
    Delivery Date
    1 April 2005
    Completion Date
    16 August 2010
    ''Mark''
    UpstateCobraGuy
    Current Owner Name
    Patrick
    Former Owner Names
    Color - Body
    Jaguar Racing Green
    Color - Stripe
    Madza Silver Frost
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.73
    Differential Type
    Tru-Trac
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • SAI Mod
    • Overriders
    • Backup Light
    • Front Splitter
    • Custom Mirrors
    • Wind Wings
    • Sun Visors
    Northeast US
    Kit & FFR Options:
    4630 RD Mark III, Powder coated frame, FFR LCA’s, 3-Link Rear Suspension, 302 Headers, Mark III Hood Hinge, FFR Radiator, and Ceramic Coated Side Pipes
    Engine & Drivetrain:
    2001 Ford Explorer 302 purchased w/2500 miles
    Holley Street Avenger 570 cfm Carburetor
    Edelbrock Performer Intake
    Edelbrock ½” Wood Carburetor Spacer
    Branda “Cobra” oval air cleaner
    K&N Filter element
    Branda Tall “Cobra” valve covers
    FRPP B-Cam
    M-6513-A50 Valve Springs
    M-6514-B50 Retainers
    Canton Roadster 302 “Road Race” oil pan
    Gas-N Stainless Steel Sidepipes
    M-7003-Z T-5 Transmission
    Heavy Duty King Cobra Clutch
    Forte’s Driveshaft
    M-4006-B373 Mustang 8.8 3.73 Rearend
    Suspension & Tires:
    17”X 9” & 17”X 10.5” Bullitt Wheels W/ Sumitomo HTR P245 45 17 fronts P315 35 17 rears
    ’98 Mustang front spindles
    FFR’s Front LCA’s w/ Koni shocks
    FRR’s Rear Complete 3-link w/ Koni shocks
    Unisteer Sport Rack 3.3 turns
    Baer Brakes 13"/12" Bear claw system
    SAI Mod
    Forte's 1" Front Sway bar
    Body and other modifications:
    Classic 5 inch “White Hot” gauges
    Forte’s Wildwood Triple master cylinder pedal assembly
    FFMetal’s Driver side footbox extension
    Whitby’s Side vents & Passenger footbox extension
    I-Squired wiring harness
    ********** Over riders
    DWC dead pedal, mirror mounts & front splitter
    Many other Breeze parts (Thanks Mark)
    FFR’s hood scoop (Thanks Dale)
    Driverside “Wyman door mod”
    Image Attachments
    Dec 2013
    FFR Number
    8220
    Delivery Date
    24 February 2014
    Completion Date
    ''Mark''
    4
    garyowens2
    Current Owner Name
    Gary Owens
    Former Owner Names
    Color - Body
    planning on blue
    Color - Stripe
    planning on white
    Engine Displacement
    428
    Engine Induction
    Carburation
    Transmission
    TKO 600
    Rear Gear Ratio
    3.27
    Differential Type
    Tru-Trac
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Heater
    • Trunk Battery Box
    • Overriders
    • Glove Box
    NorCal US
    Image Attachments
    Oklahoma
    FFR Number
    F5R1007406RD
    Delivery Date
    18 December 2010
    Completion Date
    ''Mark''
    4
    Duzie
    Current Owner Name
    Charles Dusenbery
    Former Owner Names
    Color - Body
    Blue
    Color - Stripe
    White
    Engine Displacement
    306
    Engine Induction
    Injection
    Transmission
    T5
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Power Steering
    • Heater
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Glove Box
    • Wipers
    • Wind Wings
    • Sun Visors
    South Central US
    Image Attachments
    Louisiana
    FFR Number
    2708
    Delivery Date
    15 April 2001
    Completion Date
    ''Mark''
    EJ III
    Current Owner Name
    EJ III
    Former Owner Names
    1 owner
    Color - Body
    Flat Black
    Color - Stripe
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    Levy 5-link
    Shocks
    Other
    ''Other'' Shocks
    QA-1 DA
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    275
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Trunk Battery Box
    • Overriders
    • Wind Wings
    • Sun Visors
    South Central US
    Image Attachments
    FFR Number
    F5R1005531
    Delivery Date
    28 February 2014
    Completion Date
    28 February 2014
    ''Mark''
    Natzacemm
    Current Owner Name
    Robert Latimore
    Former Owner Names
    Gordon Levy
    Car Was Complete
    Color - Body
    Lamborghini titanium silver
    Color - Stripe
    None
    Engine Displacement
    347
    Engine Induction
    Carburation
    Transmission
    Levy T5
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    IRS
    Shocks
    Other
    ''Other'' Shocks
    Levy QA1 double adjustable
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Roll Bar Type
    Single Span
    Optional Equipment
    • Power Steering
    • Trunk Battery Box
    • Wind Wings
    Texas US
    480hp LR 347, 11-1 compression, aggressive LR cam, tons of port work and port matching, 750 carb, LR Wilwood brakes, LR T5 super alloy trans
    Image Attachments
    Yorktown, IN
    FFR Number
    FFR3551
    Delivery Date
    2 May 2002
    Completion Date
    31 October 2003
    ''Mark''
    ghalleck
    Current Owner Name
    George Halleck
    Former Owner Names
    Color - Body
    Spectra Blue with Mica
    Color - Stripe
    Mazda white with hand painted red pinstripes
    Engine Displacement
    347
    Engine Induction
    Injection
    Transmission
    TKO 500
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    275
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Power Steering
    • Heater
    • Foot Box Vents
    • Drop Butt Mod
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Custom Mirrors
    • Wipers
    • Custom dash
    • Wind Wings
    • Sun Visors
    Northern Central US
    Baer Brakes front, adjustable sway bars, fire suppression system, custom carpet, custom headrest, fuel cell, soft top, toneau, car cover, Honda S2000 start button, dropped passenger footwell, Roush 347R (first customer motor), Gordon Levy version Koni adjustable shocks with heavier springs, all braided SS hoses, custom PS system with cooler, Accusump 3qt., windshield mirror rod.
    Image Attachments
    Feb 2014
    FFR Number
    f5r1008178rd
    Delivery Date
    5 November 2013
    Completion Date
    ''Mark''
    4
    msbluesman
    Current Owner Name
    owen richards
    Former Owner Names
    none
    Color - Body
    white
    Color - Stripe
    blue
    Engine Displacement
    306
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    245
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Heater
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Wind Wings
    • Sun Visors
    Southeast US
    Image Attachments
    FFR Number
    F5R1008272RD
    Delivery Date
    26 May 2014
    Completion Date
    ''Mark''
    4
    malbeck
    Current Owner Name
    Thomas Malbeck
    Former Owner Names
    Color - Body
    Darkgrey
    Color - Stripe
    Orange
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    TKO 500
    Rear Gear Ratio
    3.55
    Differential Type
    Torson
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    265
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Heater
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Wipers
    • Wind Wings
    • Sun Visors
    Western Europe
    Image Attachments
    Jan 2013
    FFR Number
    3033
    Delivery Date
    26 September 2001
    Completion Date
    23 July 2002
    ''Mark''
    ricobrafan
    Current Owner Name
    Chris Benson
    Former Owner Names
    Mark Reimels - Builder
    Car Was Complete
    Color - Body
    Silver
    Color - Stripe
    Titanium Silver
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    4-Link
    Shocks
    Bilstein
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    235
    Tire Size - Rear
    275
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Foot Box Vents
    • Wind Wings
    Northeast US
    After purchasing the car, I have been attempting to remove many of the donor parts. Winter projects have included:
    Maximum Motorsports Rear Lower Control Arms and Bilstein Shocks (removed quad shocks)
    Pro Launch rear diff cover
    Breeze front brake lines
    73 mm bore front calipers with slotted 11" rotors
    Forte's degas tank and overflow tank
    Breeze hood hinge kit
    FFR Front Upper and Lower Control Arms
    FFR Aluminum Radiator and new hoses
    Upgraded 3g alternator and new wiring
    Corba Earl vent system
    DEI header wrap and Ez-Cool Insulation
    3g alternator and wiring
    and a few I am sure I missed.
    The car has been a blast to work on and drive. Several autoX events and hopefully a track day at Thompson Motor Speedway in 2014
    Image Attachments
    FFR Number
    F5R1006789RD
    Delivery Date
    4 October 2008
    Completion Date
    ''Mark''
    3.1
    Snakedancer
    Current Owner Name
    Karen Gabriele
    Former Owner Names
    Color - Body
    Indigo ink blue pearl
    Color - Stripe
    Marble white
    Engine Displacement
    351
    Engine Induction
    Carburation
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Tru-Trac
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    235
    Tire Size - Rear
    295
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Heater
    • Trunk Box
    • Bumper - Front
    • Bumper - Rear
    • Wipers
    • Wind Wings
    • Sun Visors
    Northeast US
    Image Attachments
    Jun 2014
    FFR Number
    FFR 1202 K
    Delivery Date
    2 August 1997
    Completion Date
    15 August 2001
    ''Mark''
    profeajohnson
    Current Owner Name
    Ed Johnson
    Former Owner Names
    Garland Windle
    Car Was Complete
    Color - Body
    Eddie Bauer Spruce Green Metallic
    Color - Stripe
    Ghost Gold
    Engine Displacement
    302
    Engine Induction
    Injection
    Transmission
    T5
    Rear Gear Ratio
    Other
    Differential Type
    Tru-Trac
    4-Link
    Shocks
    Other
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    235
    Tire Size - Rear
    275
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Radio
    • Heater
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Custom Mirrors
    • Wipers
    • Custom dash
    • Wind Wings
    • Sun Visors
    Central Cal. US
    Classic 427 SC replica faithful to the FFR formula. Based on a low mileage Mustang Cobra donor, car features all leather interior, wood wheel, tonneau cover, top and most FFR options.
    Image Attachments
    ...master of none. CapeCoralCobra's Avatar
    Cape Coral, FL, via Annapolis, MD
    FFR Number
    7172RD
    Delivery Date
    14 March 2010
    Completion Date
    12 January 2011
    ''Mark''
    3.1
    CapeCoralCobra
    Current Owner Name
    Alan
    Former Owner Names
    Color - Body
    Viper Red
    Color - Stripe
    Pure White
    Engine Displacement
    Other
    Engine Induction
    Injection
    308
    Transmission
    T5
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    4-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    235
    Tire Size - Rear
    295
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Foot Box Vents
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Glove Box
    • Wipers
    • Wind Wings
    • Sun Visors
    Gulf US
    Image Attachments
    Mount Dora FL
    FFR Number
    F5R1007906RD
    Delivery Date
    9 October 2012
    Completion Date
    ''Mark''
    4
    MTDR
    Current Owner Name
    Tim Wetherell
    Former Owner Names
    Color - Body
    black
    Color - Stripe
    Engine Displacement
    5.0 Coyote
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.31
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    255
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • AC
    • Trunk Box
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Glove Box
    • Wipers
    • Wind Wings
    Southeast US
    Image Attachments
    Jul 2014
    FFR Number
    F5R1008021RD
    Delivery Date
    28 February 2013
    Completion Date
    ''Mark''
    4
    glfnut
    Current Owner Name
    John Christiansen
    Former Owner Names
    Color - Body
    red gelcoat
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Carburation
    393
    Transmission
    Other
    tko600r
    Rear Gear Ratio
    3.27
    Differential Type
    Tru-Trac
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Trunk Battery Box
    • Custom Mirrors
    • Wipers
    • Custom dash
    • Wind Wings
    • Sun Visors
    NorCal US
    Image Attachments
    Junior Member FFR7434's Avatar
    Jan 2012
    Houston, TX
    FFR Number
    F5R1007434RD
    Delivery Date
    28 April 2011
    Completion Date
    8 August 2014
    ''Mark''
    4
    FFR7434
    Current Owner Name
    Damon Dawson
    Former Owner Names
    Color - Body
    Wind blue (4e)
    Color - Stripe
    Engine Displacement
    302
    Engine Induction
    Stack Carburation
    Transmission
    TopLoader
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Pin Drive
    Wheel Size
    15''
    Tire Size - Front
    245
    Tire Size - Rear
    275
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Heater
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Custom Mirrors
    • Wipers
    • Custom dash
    • Wind Wings
    • Sun Visors
    Texas US
    Image Attachments
    FFR Number
    FFR4461K
    Delivery Date
    17 June 2003
    Completion Date
    ''Mark''
    Bobs
    Current Owner Name
    Bob Santosuosso
    Former Owner Names
    Raymond Dinorcia
    Car Was Complete
    Color - Body
    Yellow
    Color - Stripe
    Silver
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    IRS
    Shocks
    Bilstein
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    275
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Radio
    • iPOD/MP3 Player
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Overriders
    • Custom Mirrors
    • Wipers
    • Sun Visors
    Northeast US
    Image Attachments
    New Jersey
    FFR Number
    F5R1004458RD
    Delivery Date
    16 February 2012
    Completion Date
    ''Mark''
    Ruli
    Current Owner Name
    Raul Ramos
    Former Owner Names
    Henry Renaud
    Car Was Complete
    Color - Body
    Metallic Candy Blue
    Color - Stripe
    Engine Displacement
    302
    Engine Induction
    Injection
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Open
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    335
    Roll Bar Type
    Custom
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Trunk Battery Box
    • Front Splitter
    • Sun Visors
    Northeast US
    Engine:
    - 95 Mustang 5.0 L
    - AFR 185CC aluminum heads
    - CompCams XE270HR camshaft, roller
    - Crane aluminum dual roller rockers
    - FMS 24lbs/hr injectors
    - Cobra intake with K&N RU-3130 air filter
    - Larger mass air and throttle body
    - Complete MSD ignition system (6AL, distributor, coil and wires)
    - Levy oil pan with functional thermostatically controlled oil cooler
    - Remote K&N HP-3001 oil filter
    - All oil lines are Earl’s braided stainless steel
    - Accusump 3.0 quart pre-oiler with manual/auto switch and gauge
    - Fluid harmonic damper
    - Ron Francis wiring harness
    - Energy Suspension motor mounts
    - Chasis dyno: 277 Hp, 300 ft-lb, corrected: 308-325 Hp, 333-352 lb-ft
    - Super-flat torque 2500-5500 rpm
    Steering/Suspension/Brakes/Transmission:
    - FMS power steering
    - Power steering fluid cooler and filter
    - Heidts power steering pressure adjust valve
    - Whitby power brake booster
    - 95 Cobra calipers and disks
    - Rear brakes pressure adjust valve
    - Tremec T-5 transmission with mid-shifter
    - FFR tubular front A-arms
    - 3 link rear suspension with 3.55:1 rear end gears
    - Safe Launch aluminum differential cover
    - Front adjustable Breeze NASCAR style sway bar
    - Vintage Performance fully adjustable rear sway bar
    - Koni coilover shocks
    Tires:
    - Kumho Ecsta V710
    - Front, 275/40-R17
    - Rear, 335/35-R17
    Wheels:
    - CCW (Complete Custom Wheels), Classic, 3-piece
    - www.ccwheel.com
    - Front, 17x9.0, work order 15039
    - Rear, 17x12.5, work order 7859
    Body/Other:
    - Full Safecraft fire suppression system (fuel tank, cockpit and engine nozzles)
    - Portable fire extinguisher in cockpit
    - Fuel Safe fuel cell
    - Easily removable full windshield and 2 spec racer windshields
    - Driver and passenger Kirkey racing seats
    - 5-point Crow safety harnesses with arm restraints
    - Removable splined steering wheel
    - Front fiberglass splitter by Tony Chiles
    - Front nose splitter by Dark Water Customs
    - Autometer shift light
    - Angled Autometer gauges
    - FFR wipers
    - Trunk mounted hidden battery
    - Rear fender flares bonded in
    - Metallic candy blue paint job
    Image Attachments
    Nov 2012
    FFR Number
    4308k
    Delivery Date
    13 October 2012
    Completion Date
    5 August 2004
    ''Mark''
    rockyspop
    Current Owner Name
    jimmy padgett
    Former Owner Names
    Danny Glenn
    Car Was Complete
    Color - Body
    bmw red
    Color - Stripe
    no stripe
    Engine Displacement
    347
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Tru-Trac
    4-Link
    Shocks
    Pro-Shocks
    ''Other'' Shocks
    Pin Drive
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Power Brakes
    • Trunk Battery Box
    • Custom Mirrors
    • Wind Wings
    • Sun Visors
    Southeast US
    Image Attachments
    mcwho's Avatar
    DeBary - Florida
    FFR Number
    FFR7287RD
    Delivery Date
    24 July 2010
    Completion Date
    ''Mark''
    4
    mcwho
    Current Owner Name
    mcwho
    Former Owner Names
    Color - Body
    Yellow
    Color - Stripe
    Black
    Engine Displacement
    331
    Engine Induction
    Carburation
    Transmission
    TKO 600
    Rear Gear Ratio
    3.27
    Differential Type
    Tru-Trac
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    235
    Tire Size - Rear
    295
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Radio
    • Heater
    • Wipers
    Southeast US
    Build is in Orogress !
    Image Attachments
    Hilo, Hi
    FFR Number
    F5R1007674RD
    Delivery Date
    19 January 2012
    Completion Date
    9 December 2014
    ''Mark''
    4
    Kinsan
    Current Owner Name
    Clifford Kaminaka
    Former Owner Names
    None
    Color - Body
    Lexus Pearl White, 070
    Color - Stripe
    Gun Metal
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.08
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Radio
    • iPOD/MP3 Player
    • Trunk Battery Box
    • Bumper - Front
    • Bumper - Rear
    • Backup Light
    • Custom Mirrors
    • Wipers
    • Wind Wings
    • Sun Visors
    Alaska / HI US
    Image Attachments
    Member Arvin's Avatar
    Layton, Utah
    FFR Number
    FFR8271
    Delivery Date
    25 March 2014
    Completion Date
    ''Mark''
    4
    Arvin
    Current Owner Name
    Arvin Brown
    Former Owner Names
    N/A
    Color - Body
    Guardsman Blue
    Color - Stripe
    Wimbledon White
    Engine Displacement
    408
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • iPOD/MP3 Player
    • Heater
    • Foot Box Vents
    • Bumper - Front
    • Bumper - Rear
    • Glove Box
    • Wipers
    • Custom dash
    • Wind Wings
    • Sun Visors
    Northern Mountain US
    Image Attachments
    Mar 2015
    FFR Number
    F5R1007097RD
    Delivery Date
    1 January 2009
    Completion Date
    ''Mark''
    papa cruise
    Current Owner Name
    Chris Moorhouse
    Former Owner Names
    Color - Body
    still in gel coat
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.31
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Roll Bar Type
    None
    Optional Equipment
    • Radio
    • Heater
    • Wipers
    • Wind Wings
    Eastern Canada
    picked up an unfinished Mark III here in southern Ontario. Most of the important parts are here. Have had some help with some parts from other members .. thanks!
    Lots to do, and hard to find anything up here other than donor mustang, or ford replacement. trying to get things across the border is expensive and a real pain.
    hope to post some progress picks as soon as I make some. lol
    curious as to where it was first imported and how much of a hassle it is going to be getting a vin and registering it without any paper work from Factory Five.
    I have another tag from " Gear Centre". I don't know if they were building it or imported it, but none answers calls there.
    Image Attachments
    Senior Member Steven K's Avatar
    Denver, NC
    FFR Number
    3906
    Delivery Date
    20 October 2002
    Completion Date
    ''Mark''
    Steven K
    Current Owner Name
    Former Owner Names
    Color - Body
    not painted yet
    Color - Stripe
    Engine Displacement
    306
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.08
    Differential Type
    Limited Slip
    4-Link
    Shocks
    Pro-Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    235
    Tire Size - Rear
    265
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Radio
    • iPOD/MP3 Player
    • Heater
    • Foot Box Vents
    • Drop Butt Mod
    • Trunk Box
    • Backup Light
    • Glove Box
    • Wipers
    • Custom dash
    • Wind Wings
    • Sun Visors
    Southeast US
    Image Attachments
