Results 1 to 3 of 3
Thread: 1997 Impreza L with WRX/STi Swap 10000$
    Cool 1997 Impreza L with WRX/STi Swap 10000$
    Hello folks, I've got a awesome donor car for someone looking to build a monster 818. I've got a ej257 with a 18g*375-400awhp on e85 . I'm looking to build a GTM Supercar so the 818 project is being nixed. The car runs starts and drives right now. If i don't sale the car whole I will be parting everything out in a month. I am open to trades also.
    I will try to taken some pictures of the car when i head up to the shop next week. It's not the prettiest thing out there but the parts in it are top notch
    This setup will easily be enough power to put a 818 into the 10s if the transmission can hold up
    1997 Impreza L with wrx/sti swap AKA the Battlewagon 10000$
    18g setup on e85 on a 2.2 made 370awhp I've not turned up the boost on the 2.5 motor
    Tocki D specs + STi Springs 400$
    WRX Brakes / subframe componotoes 600$
    RWD Trans $150 * i do not know how this transmission will hold up its a modified 1997 impreza l awd gear box to be rwd
    Welded Rear Diff 150$ * Welded
    EJ257 with rebuilt ej205 heads ~5000 miles 2500$
    Custom clutch for 97 Trans by southbend 100$
    03 ECU *speed densitiy 250$ &supports map switching / launch control and much more
    Sony Stereo 50$
    All new speakers for the doors nothing fancy but they don't sound half bad 100$
    Alarm 100$
    custom wiring to make stock dash work with 03 WRX setup this took over 60 hours to complete it's not much simpiler and would make swapping this into another car 100000X easier
    Forced Performance 18g turbo ~ 10000 miles 500$
    Halman MBC 40$
    FIC900 cc injectors 250$
    wally255 50$
    turbo inlet 40$
    KN short ram typhon intake 100$
    03 WRX Seats 250$
    TGV Deletes 100$
    minor porting in header 150$
    grimmspeed uppipe
    generic downpipe 50$
    CBE with borla muffler *kind hacked together atm but it sounds sexy *100$
    WRX Stock TMIC 50$
    BOV/Bypass valve 50$
    03 WRX Rims with tires * some tread left and the rims are rough as they are my winter setup 200$
    Black 17 inch rims * need new tires 300$
    ddm hid kit for 03 wrx 20$
    Group N mounts 50$
    03 wrx airbag and steering wheel 150$
    +EXTRA
    full forrester XT drive line 70k miles
    Various 03 wrx bushings
    03 WRX gear box + sti ra gear set with broken second gear . new shirt forks and syncros thrown in ~15k ago
    Southbend clutch and reman flywheel for 03 wrx
    more pics to come
    OBO btw also open to trades
