I have the DS LCA & UCA mounted, axle in, and spindle (knuckle) mounted to the arms. The hubs slide onto the axles fine by themselves, but when trying to slid them on into the spindles over the axle they "stick" after about a 1/2" of insertion.
I then tried to slide the hub into the spindle of the PS (not mounted, not onto the axle), and it does the same thing. I have tapped to try and "persuade it" on further, but no dice. I didn't smack it too hard, as I didn't want to muck it all up right away.
So then I stuck the hubs in the freezer overnight, same thing.
Now I have both the PS hub and spindle in the freezer for the day and will try that tonight. Is this tight a fit "normal", or is it something that I am missing. Any alternatives or suggestions would be appreciated.
TIA
