Results 1 to 5 of 5
Thread: Tremec 5 Speed (M-7003-R58C) Mid-Shift?
    Member JeepFlyer's Avatar
    Clovis, NM
    Tremec 3550 5-Speed Mid-Shift?
    Does anyone know if the Tremec 3550 5-speed (part# M-7003-R58C) can be converted to a mid-shift to move the shifter forward on the transmission tunnel? I've seen places online claiming it is a TKO 600... is this true? Would substituting a TKO 500/600 for this change the installation with a coyote?
    Northern CA
    Yes,
    You can use a 3550, which this is below, or the newer 600.
    Hank
    Clovis, NM
    Would a TKO 500 work? The coyote is only rated at 390 ft/lbs so that would be well under the max rating. It just seems like the 600 would be overkill if I didn't have plans to increase the output anytime soon.
    Northern CA
    Any of the TKO'S would be fine, the newer models shift much better than the older 3550's.
    Hank
    Bill_VA's Avatar
    Manassas, VA
    Just call Mike Forte, he knows everything about Tremec transmissions.
    Non-donor - Engine Factory 351w/400hp - TKO500 - 3-Link - Cobra brakes - FFmetal - Wilwood pedals - FR500 wheels - NCPainter
    Owner of FFmetal.com
