Results 1 to 8 of 8
Thread: Rear view mirrors on the S
    Houston
    If I've missed a post on this, I apologize in advance.
    With the mirrors mounted rigidly to the windscreen posts as on the SEMA car, the mounting brackets extended towards the rear of the car. The doors would swing open under those mirror and mounts. It seems that this arrangement could not be used if the doors had windows. See rather poor pic attached
    Did I miss something.
    Since the car will not have roll up windows in this version I don't see that as a problem. I am sure if FFR has a later version with roll ups this will be addressed. For kit constructors that want to install their own roll up windows, I always say if there is a will there is a way.
    Houston
    Agreed, I just thought some of the photo-shop guys doing a top of some sort might not have noticed. When imagining a top + windows, mirrors on the doors (or wherever) should be included to complete the picture.
    Exactly. Just one of the hundreds of finesse points when coachbuilding a coupe with windows. The mirrors get mounted on the fenders or door skin, and then you have to deal with them being a significant issue in aerodynamics and wind noise. Mirrors are considered one of the top three problem areas for cleaning up air flow.
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    There's no doubt the mount point will need to change to accommodate roll up windows. Also the door itself is too small to allow a full length (from the front of the door to the rear) window to roll down. The natural solution is a wing window type structure (doesn't need to actually have a window). This would reduce the size of the window, and allow for a mirror mount point on the door itself.
    The wing window could also be fixed to the body, with the mirror left as-is. The door would still open under it, and the slightly pushed back roll-down window will clear it all.
    Senior Member shim2's Avatar
    I'm curious about that giant gap from the mirror to the door. Maybe I'm seeing things, but if I'm seeing what I think I am, that doesn't look good.
    Senior Member narkosys's Avatar
    I agree. To me that makes it scream kit car. Hopefully they will be addressing that considering the mirrors where a last minute rush to get the cars out the door for SEMA.
    P
