Results 1 to 13 of 13
Thread: Frame Dimensions
    Senior Member hdnik's Avatar
    Welland, Ontario Canada
    Frame Dimensions
    I'd like to build my Chassis Dolly before my kit arrives. Could anyone be so kind as to confirm the dimensions I've been able to glean online and fill in the blanks A, B, C and D for me on this drawing.
    Thanks!
    Tech Support, FFR
    Here is what the dimensions are:
    A= 46.0"
    B= 54.0"
    C= 24.0"
    D= 49.5"
    Thank You
    Dan@FFR
    wheels
    Quote Originally Posted by hdnik View Post
    Thanks!
    Go to the FF forum and look at my pics in the gallery just search Buck70 pics
    I think it's the best dolly option yet.
    Dale
    Thanks Dale Found them.
    Thanks Dan exactly what we need
    Dan. Thank you again.... so does this look about right?
    One more thing if anyone knows off hand. How much does the bare chassis weigh. Can 2 men move it from the crate onto stands?
    Thanks again. Nick
    Tucson, AZ
    I don't know how much it weighs but it won't be delivered in a crate and the truck driver will off-load it for you with a pallet jack. Have your jack stands, etc. ready and he'll put it on them for you.
    Milton,DE
    You are right Strip, usually there isn't a crate, unless Nick lives outside of the States. Then he would most likely have a crate.
    Nick, it is always a good idea to post your location in your profile for us to see. You never know, there might be someone in your hometown building an FFR.
    2 men can move the chassis. That would be 2 men that are used to some manual work. Otherwise, get 3 friends to help.
    Olli
    Thanks again. Nick
    Nick
    The bare chassis weighs 280#'s Two men can lift it and carry it a short distance. Once it's inside you can lift one end by yourself and anyone big enough to
    heft a jackstand can place them for you. But my approach leaves all the jackstands free for other components.
    Dale
    Quote Originally Posted by Olli View Post
    Olli
    I have updated my profile. Thanks for the heads up!
    Yes from Canada apparantly it will be in a very large crate when it arrives. I want to have a dollie made prior to its arrival so it can be moved around... working in a tight 2 car garage.
    Glad to know it can be manhandled a bit
    Here is my dolly idea. Kind of merged a bunch of different ones I've seen here and on other forum.
    Thoughts?
    These are available at HF for 18 bucks each. 450# load rating
    Senior Member Barrel's Avatar
    Aug 2011
    Mornington, Victoria, Australia
    I have been there before with my Roaring Forties GT40 build and now with the 33 HR and my advice is this. Whatever dimensions you arrive at make sure that when the car is on the dolly it's at a height that you can be sitting down when working on it. I used the same dolly for both cars and compensated for the different dimensions with timber framing. Oh, and get a comfortable stool.
    Dolly Completed Today
