Hey guys,
My battery died over the weekend and needs to be replaced, no biggy. But what is a royal PITA is the fact that my PCM is now throwing out DTC's P1336(Crankshaft Position (CKP) System Variation Not Learned (SES) and P0300(engine misfire detected) error codes which mean that the Crank sensor value needs to be "relearned". These two errors go hand in hand and mostly occur together because the PCM no longer knows how to time the spark properly because the crank sensor isnt calibrated anymore. Apparently, this can happen if your battery is pretty weak and the PCM can "forget" the value it has stored. It also occurs with an engine rebuild and a PCM replacement. This "relearn" procedure in a stock Corvette is a piece of cake.
In a GTM however, its a problem because the process to activate the calibration feature in HPtuners (or any tuning program for that matter) is not possible in a GTM unless you have the brake light switch wired into the PCM so that it knows you are pressing the brake. Oh, and the PCM has to know if the auto gearbox is in park or your manual is in neutral too. Without this info, it wont allow you to start the CASE learn process. So, what the heck can we do if this happens to us GTM builders Without the need for rewiring to fool the PCM? Or any other custom car builders who use an LS engine? I read somewhere online that in HPtuners, you can bypass these requirements but of course, conveniently, this post doesnt say how. Nor does the help file in HPtuners or the HPtuners forum. Has anyone had to do this in their GTM? Perhaps when they worked their engines and upgraded them? As i said, its a simple thing to get rid of providing your wiring is as Chevy intended in a Corvette.
Thanks, Tom!
