Results 1 to 3 of 3
Thread: Temporary set-up to hold the MAF on an LS3
    I'm looking for a cheap, functional way to house the MAF on my LS3 while I'm in go-cart stage. Right now I have the rubber adapter which connects the intake to the standard conical air filter - no place to hold the MAF. Anyone have a quick way to set this up?
    I realize this won't meet the requirement of X inches away from the manifold in a straight segment, etc. but I'm just looking for something adequate until I put in the full cold air intake. The engine is running rough at idle and I'm presuming that's from the MAF just hanging near the air filter assembly.
    Thanks.
    Senior Member Kempo's Avatar
    Cabo Rojo,PR. USA
    You can use a piece of 4" diameter PVC pipe. Make a slot on it and use duct tape to hold the MAF sensor in it.
    GenII GTM #354
    Delivered (02/09/11)
    Maf
    I used aluminum 4" Dryer Vent. It 's thin and I would recommend using the duct tape
    for the MAF Sensor.
    Quote Originally Posted by dreabrown View Post
    Thanks.
