Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 408
Thread: GUNS' 818SR Build Thread
  1. #201
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    Did you buy the 10' section or the 50' roll?
  2. #202
    Jan 2012
    How much of the ez cool did you use sq ft?
  3. #203
    Xusia,
    I bought the 10ft roll and that should be plenty for what I plan on using it for. 50ft would be a ton of this stuff!
    Fireblade,
    I think each half used about a 23in x 23.5 in square and then I trimmed as required. Roughly 8 sq ft. total.
  4. #204
    Kirkland, WA
    Quote Originally Posted by GUNS View Post
    I used it in my challenge car and will say I won't use it again, does not hold up, so will go w/o this for my R build
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  5. #205
    How are you guys passing the throttle cable through the firewall? Manual says to drill a 1/4 in hole through the firewall and pass the cable through. Only problem is all of the hardware on the cable ends are >1/4 in. Maybe I'm dumb, but I can't figure it out other than drilling a much larger hole or disassembling the cable. Also, once the cable is through, how are you guys routing the cable? Thanks.
  6. #206
    Senior Member waruaki's Avatar
    Salem, Oregon
    I don't recall the size of the top hole it just needs to be big enough to squeeze the crimped ball at the end of the cable through. The bottom ended up being a U letter drill .368 I believe the picture shows our cable placement. the cable lays in the tunnel then over the top of the tank and across the motor to the throttle body.
  7. #207
    Thanks waruaki, that helped immensely!
    Here's what I did. I drilled a 1/2" hole (manual says 1/4") in the firewall and had to punch the ball and plastic crimp through the hole:
    I then used a 3/8" E-Clip from lowes to act as a washer for the cable to attach to the firewall:
    I then drilled another 1/2" hole to allow the cable to pass through the trans tunnel.
  8. #208
    Well today is officially 1 year later from when I started tearing down my perfectly good WRX to prep for this project. Even though it's taking a while, I'm still having a blast and learning a lot as I go. So far I have 206 hours into this project, including the WRX teardown.
    So here's what I got done today. I finally riveted the interior aluminum. I postponed this until I was comfortable that I wouldn't need to make any changes. I'm glad I did, because it wasn't until recently that I learned there is a coolant tube cover that someone else discovered. The manual does a good job of getting you started and then just moves on to something else. It is definitely incomplete.
    Here's the passenger side. The driver side looks the same. I decided not to powder coat it since I plan to cover it in carpet. I did however give it a coat of Sharkhide to hopefully protect it from corrosion.
    I also put the fuel tank together using a DW200 fuel pump. It was kind of a PITA to install, but I finally got it to fit just right. I test fit a layer of EZ cool on the bottom of the tank to aid in sound deadening and heat (another stolen idea).
    The manual says to rivet the lower firewall to the floor pan. I don't like this idea as it will essentially permanently install the fuel tank. I think I'm going to go with an nut & bolt setup instead in order to have the option to remove the fuel tank if I ever need to.
    Depending on my work schedule, I'm hoping to install the engine/trans this coming week.
  9. #209
    ok guys, need a little help with mating the trans and engine back together. I've got everything lined up and all bolts threaded, but I'm getting a lot of resistance from the bolts as I get the trans & engine close. I fear that I've already done some damage to the threads and don't want to do anymore.
    Any ideas?
  10. #210
    Huntsville, Al
    I had/have the same issue....I just went slow and it finally went in. I also put a socket on the crank and rotated that while I tried to line it up...it never did slide in like I am use to.
  11. #211
    Nov 2012
    Zeeland, MI
    Any ideas?
    my guess is would be the trans output shaft that is splinded is not aligning with the splines on the clutch plate. it took some wiggling on mine to put it together. sometimes when you reassemble the clutch and pressure plate there is an alignment tool. I just eye balled center
  12. #212
    Thanks for the response Eric, that makes me feel a little better. I just hate wrenching on bolts that are fighting back. I definitely cross threaded one of nuts that goes on one of the lower studs. The stud actually unthreaded from the bell housing.
  13. #213
    Huntsville, Al
    Well you might need to back the tranny off and wiggle and try and poke it back in
  14. #214
    Hey Guns,
    There are two 10mm alignment pins that are use for the last 1/2" of travel. Are they damaged or corroded?
    Nope, they are fine and are all lined up.
  16. #216
    Huntsville, Al
    yeah know...I just noticed...you have the starter in ....I typically wait until the tranny is seated before I install the starter. This allows me to move the flywheel ever so slightly to get the clutch disk onto the input shaft of the tranny....
  17. #217
    Freeport, ME
    Mine was a PITA too, it took a ton of wiggling. I'd remove the starter too and work really slowly clamping it together with the bolts.
  18. #218
    Mechie3's Avatar
    Two of the bolts are longer than the others. I use these to pull the top together without the starter. After it's done and together I remove those bolts, put the starter back in and then bolt it together.
  19. #219
    Exeter R.I
    Exactly how I do it, it works well.
  20. #220
    Thanks for the advice guys. I got it very close to sealing by slowing tightening each bolt and just when i thought I had it, one of the bolts stripped. So I took removed all the bolts, released the fork and bearing and tried to back the trans off the engine...and now it's stuck. I have a good couple of inches of separation from the bell housing to the engine, but it won't budge. I can wiggle around a bit, but it seems like the output shaft is hung up. I tried using a pry bar, but it only goes so far before I get a lot of resistance. I'm really hoping I didn't cross thread the splines or anything. Any ideas?
  21. #221
    Guns
    If you have a couple of inches between the engine and transmission, you can loosen the clutch cover bolts. The will allow the clutch disk to float and should let you pull off the transmission.
    See if someone else replies here also to see if my suggestion makes sense.
    Thanks Bob. I actually just did that. Got the trans off and looks like I did indeed cross-thread the splines, so now the clutch/pressure plate are stuck on the output shaft. I need to figure out how to get those off and assess how badly I damaged the output shaft. Suck.
  23. #223
    Mechie3's Avatar
    What style of clutch? If it's a pull clutch, the bearing might have already locked onto the pressure plate. you'll have to remove teh plug on the side of teh trans near the fork and release the fork from the bearing.
  24. #224
    Yea, i had already released the bearing. Not sure if maybe it got stuck on the pressure plate, but from what I can see i don't think it did.
  25. #225
    Welp, I learned some lessons the hard way, but I was lucky that there was minimal damage. Turns out the I did cross-thread the output shaft and clutch splines which essentially fused the clutch disk to the output shaft. The clutch had to get torched to be removed, but the splines on the output shaft were not damaged. So in the end I got away with just needing a new clutch disk...could have been much worse. So as advice to anyone else doing this, make sure you use a clutch alignment tool. I did not the first time around which lead to my "issue." Because of the miss-alignment, I also stripped the threads in the engine block. I had to install Heli-Coils in all holes.
    With that being said, I finally got everything back together and got the engine & trans installed:
    The install was pretty straight forward due to the advice of others.
    I was also able to get the radiator installed and plumbed.
    Even with using the sifter bushings as spacers for the bottom of the radiator, I still had clearance issues with the lower Rad hose and the steering rack boot. So I installed a simple hose clamp that hold the corrugated hose up just enough to clear (hard to tell in the pic, but there's about 1/4 in of clearance):
    I struggled with the hose adapters for a bit until I figured it out. The hose adapters come with sleeves. Remove the larger diameter one and discard. This is where the corrugated hose will go. Use plenty of dish soap to help get them on.
  26. #226
    (continued)
    I also recommend connected the inner sleeve to the steel tube while it's off the car. Install the inner sleeve first and then install the outer portion. I made the end of the tube flush with the inner sleeve to leave enough room for the corrugated tube.
    Here it is all done:
  27. #227
    Kirkland, WA
    FFR's radiator hose setup is nasty on the Cobra and it is nasty here also, which they would learn
    Tony Nadalin
  28. #228
    Exeter R.I
    Not to tell you to move the drivers front flex line, but it should go on the inside of frame and the aluminum wheel wells. They are rather thin and can get damaged easy.
  29. #229
    Thanks for the tip, I'll take a look at moving it. I wish the manual would have stated where to route them :/
  30. #230
    Exeter R.I
    look at my thread and others, pm me anytime man
  31. #231
    Thanks Metal, I appreciate the help. I typically look through threads before starting a new section, but I sometimes miss things. It looks like it should be a relatively easy fix.
  32. #232
    Exeter R.I
    Yea it's no biggy, it is looking clean so keep up the good work!!
  33. #233
    nkw8181's Avatar
    Dallas, TX
    Looks like I found another good build thread that I missed and now must follow. keep up the good work!!
    Nolan
  34. #234
    Re-routed my coolant hoses based on Metalmaker's suggestion. Zip ties are temporary, I'll work some kind of bracket similar to the one above.
  35. #235
    Mechie3's Avatar
    I bought more of the orange silicone coated P clamps from mcmaster to hold my hoses.
  36. #236
    Kirkland, WA
    I wish there was a better way to do the hoses, as the flex hose does not hold up, as after a year on the track with my challenge car I had to replace all the stock flex hose, lucky with the challenge car I could find real hoses that worked, but here with the run so long it will be impossible, someone just has to make something
    Is that the stock WRX fan on the radiator ?
    Tony Nadalin
  37. #237
    Huntsville, Al
    the hose on driver's side at the back it too far back, it will run into the wheel well aluminum if you install it. I cut about 6 inches off the end of the aluminum tube so the coupling is where you have the clamp.
  38. #238
    Mechie3's Avatar
    Mike everson made some bent hard lines that replace all flex hose. He has a thread in the general 818 section with details.
  39. #239
    Erik, thanks for the point out. I noticed that too and was planning on trimming it down if needed.
  40. #240
    Kirkland, WA
    Look real nice, but expen$ive (more that I can afford) ! Time to go to my roll cage builder and have him bend some aluminum tubing, even better may be a long run of the Gates Green StripeŽ Wire Inserted Coolant hose would be better than the FFR setup and you don't have to worry about all the connections and hose clamps and @ about $10 foot still cheaper.
    Tony Nadalin
