Thread: Oil Filter Relocation
    Opinions please...My engine is is 347ci with oil filter mounted on the block (normal position)....I seem to be able to get to it fairly easily. Why would I relocate it? Any advantage that I'm not seeing? Seems just two more hoses that may leak.
    Walter
    Blue Oval Scribe Mustang Man's Avatar
    Lakeland, FL
    The relocating kit included is a must if you use shorty headers and J-pipes, as the headers mount backwards (collectors forward) like a turbo kit. If you are using the BBK 4-into-4 headers you have plenty of clearance to leave the filter on the block. I have a sandwich adapter for the oil cooler and still plenty of room to thread the filter right on.
    Mark
    Modified Mustangs & Fords Project Snake Charmer
    FFR5310 Mk 3 Roadster
    Tungsten Gray/Silver Stripes
    Senior Member tcoon's Avatar
    Angwin, CA
    You can also use a 90 degree adapter to angle the oil filter down. This avoids use of the relocator and has worked well for extended duty use in endurance racing.
    -T
    Coyote powered Daytona Coupe Competition Racecar #21
    Challenge series #21
    FFR 33 Hot Rod
    2009 3rd place NorCal series
    2010 3rd place West Coast series
    2011 2nd place NorCal, 2nd place West Coast Series, 3rd place WERC class E1
    Thanks for the replies - my problem still is thinking everything supplied with the kit (eventhough I have not many parts already) should be used. Yes I'm hoping to get away with the longer/higher mounted headers. Walter
    greenwood sc
    The number of leftover parts will be directly proportional to the amount of time you spend on the forum.
    MKIV #7619 complete kit IRS, 351 TKO 500, Delivered 11/13/2011
    First start 12/31/2011
    Gocart 01/12/2012
    completed tags/title 05/11/2012
    http://thefactoryfiveforum.com/showt...-Graduate-7619
    Walter,
    I'm using the 90 degree adapter with the short oil filter (purchased from Mark at Breeze Automotive) on my 410W with Ford Racing shorty headers (I fabricated an under car exhaust system) and there is plenty of clearance. I had thought about the remote filler but found the adapter to be much simpler, i.e., less connections to leak. Ernest is so right about the leftover parts. I now have a large plastic tub full of them.
    Ron
