0
0
Wheels and tires MAKE a hotrod!
The attitude is in the wheels, tires and rake. And a hotrod needs attitude. I am getting ready to buy rubber and wondering how tall anyone has gone without fenders. Oh yeah, real hot rods don't have fenders. I'd like to see some photos of different tire/wheel sizes and especially if yours has something besides 305/35/18/ and 235/40/17 . I wish there was a whitewall tire available for 18 rears and 17 fronts? It would go just perfect with the 1956 Lincoln Continental Wisteria paint I am working on.
Any photos out there?
EFI Rules and Carbs Drool
The reason you don't see a lot of big rear tires is there isn't enough clearence. Since the driveshaft runs through the frame, it limits how high the rear of the car can go before the driveshaft hits. I have 29" tall rear tires and it took a lot of modifications to make it work. (I normally have the rear suspension adjusted higher than this so the tires don't hit the fenderwells)
trans length
Originally Posted by
Arrowhead
The length of the transmission plays a big part in this too. I am using a 46RH dodge auto which has the rear OD on it. The housing ends up flush with the tunnel loop and the U-joint is a few inches behind that. Moving the front U-joint back with a longer tranny gives a lot more suspension travel for the rearend before the driveshaft hits anything. It also gave me enough room to lower the battery shelf to hold a full size 27 series battery. I don't have an answer yet for the limit on tire size due to fenders though.
DB
Hemi 33
Got it. Thanks for that clear answer. So what would be your guess as to a tire height that would not rub. A loaded shock has about how many inches of difference from high to low, stiff to soft? Do the handling characteristics change from a taller tire? I am basically an old school guy built cool rods and this is my first "modern" rod (OMG A/C !) , seems it needs a tall tire and raked.
What kind of modifications did you need to do for the bigger tire /wheel size? Which rear axle width are you using? Does the wider 5 lug rear give more room for tire height?
Dreamer
In some countries fenders are mandatory....
j33ptj
Which explains why so many people want to live in the USA!!
Amazing and interesting information about the tires i see with the help of pics that front wheel adjustment is very different to the others..Can yo describe me the front tires of this car.If you send me the link of the drive of this car i shall be very thankful to you.
So the tire questions also include the "look" of the tread for fenderless cars (meaning real hot rod). How much traction can I get? I want this car to stick like my go kart! 18 x 10 and 17 x 9 front
Sumitomo HTRZ II tires are a common choice. Noisy? Do you have these tires? Let me know. If they are noisy, how much road noise can I overcome with sound deadener? Or where can I buy real good earplugs for my ipod?? My 302 Ford is rebuilt and about ready to go in next, tires cannot wait much longer.
Tire ideas??
- You may not post replies
- You may not edit your posts
Forum Rules
