Results 1 to 3 of 3
Thread: Cobra Factory five offered at 60k - 90k invested. VIN F5R1005921RV Somg legal 50 st
    Jan 2013
    I messed up the first post with incorrect title, and pictures. Sorry first time on thread.
    https://www.youtube.com/watch?v=KK7m2koZdHw
    https://www.youtube.com/watch?v=ZGE2oK2bfBk
    The kit was bought in 2007, I spent the next 3 years building this machine, and it was a lot of fun!. Factory Five chassis is one of the best in the industry compared to Superformane. Superformance cobras are going for 55k plus without drive tran. This cobra has a substantial drive tran backing the best chassis and body.
    The interior is completely custom and sound proofed with Dyno mat, as well as the trunk. No expense was spared on the build, every upgrade was put into it, from the duel Roll bars, the larger foot box (thinker sheet metal) down to the Independent rear end and every part is NEW.
    The Body was painted by Automotive Enterprises, they are the best in fiberglass work in the Bay Area. The body was stress relieved ( this stops spider webbing and cracking). The underside of the body is coated to stop rock dings. Factory Five Bodies are not part of the structure of the vehicle so the body will not crack during torque loads, cornering, ect.. The Frame is powder Coated black. You will notice the car is a very bright red out of sun, in the sun it has a little orange to it. The Paint is from Enzo Ferrari
    I originally built the car to autocross and enjoy on the weekends. I have not raced or Autocross the car and only put on 600 miles to work out the kinks. I have a new interest in mind so I need to make room for the next project!
    Body / Chassis
    Factory Five Chassis / Body 2007 MkIII Roadster Kit _SB100 California registered, so is smog certification exempt for life.
    Add ons From Factory Five
    Thicker Gauge sheet-metal on floor and Foot Box - Gives you and extra inch of Room
    Duel Roll bar
    Real Leather Seats
    Visor and Wind wing
    Brake Duct Wire Mesh
    Real Leather Steering Wheel
    Hood Scoop
    Ron Francis Wire Harness
    4 point seat belts - Simpson
    Engine: 450+ HP I have not run on a Dyno
    351W Bored and Stroked to 408
    REAL Blue printed and balanced
    Fuel injection: Mass Air 42lb injectors
    Mass air ECU
    AFR Heads : 205CC f/sb-205cc x 58cc x stu
    CAM: Crane - H-roller .540/.560 225/232
    Hydraulic roller Lifter
    Roller Rockers
    High volume oil pump
    Baffled oil pan
    Crank: Forged 4340
    Connecting rods: H - Beam steel rods Forged
    Pistons: RSS forged aluminum
    molly Rings
    Manufacture of short block: high performance Racing, out of Florence CA
    3/4 Tube aluminum Radiator
    Thermostatically controlled electric Fans
    Jet Hot Coated SST headers and side pipes
    Drive Tran:
    Centerforce Clutch (duel Pressure plate)
    TREMIC TKO-500 31 Spline
    IRS (independent Rear Suspension)
    Fully adjustable springs and Shocks
    Torsen Diff 28 Spline 3.55:1
    5 lug
    Suspension:
    Fully adjustable shocks and coil overs - Front and Rear
    Tube "A" arms
    Power Rack steering
    Drilled Slotted brakes front
    4 piston front 2 piston rear
    G force street slicks
    F355 - 35 R17
    R255 - 40 R17
    Hidden extras
    Factory five powder coated frame
    Breeze Automotive lower radiator support kit
    Breeze Automotive Fan Shroud
    under dash filler panel
    FFMetal rear mounted battery box
    Jan 2013
    Husband/father/son mrmustang's Avatar
    Greenville, SC
    great looking car, does the car have wipers, heater, a fitted top?
    Bill S.
    Instead of being part of the problem, be part of a successful solution.
    HOW TO BUY A USED COBRA
