Thanks Thanks:  9
Likes Likes:  99
Page 28 of 48 FirstFirst ... 18262728293038 ... LastLast
Results 1,081 to 1,120 of 1908
Thread: Mechie3's 818S
  1. #1081
    Mechie3 The Hella LED ring & center Lights are sweet! Probably would only be able to only use one per side though, not really enough room for a pair. Trust me I layed them out in a mock-up. If FFR didn't taper the rear of the car so much a did it closer to the Vantage design, might be able to do a pair, maybe. The Hella LED & center light gets pretty big.
    I love Susquehanna Motorsports (Rallylights.com) probably one of the best if not the best source for Hella lights.
    Speaking of the more "squared off look" like the Ferrari. It brings to mind my so called "wide body" idea, which really isn't wider. It is taking the FFR smaller fender flares off and moving the whole fenders out to where the old flares were and giving less of a round over on the top, mostly the rear. This would give the 818 a wider look without being actually wider. It would also allow for more room in the rear width wise to do more.
    Mechie3's Avatar
    Indianapolis
    Here's a partially finished steering rack mount. I took the design I already had and cored it out a little and added corner radii. The bolts actually pass through the open area (no bolt holes made yet, ran out of time). I did a quick FEA of the bolt and it can withstand over 2,000lb of clamping load with a factor of safety over 4, so I think it'll survive.
    Zero Decibel Motorsports
    Check out my new website!
  3. #1083
    San Diego & Riverside CA
    very nice, another cool zero decibel product!
  4. #1084
    nkw8181's Avatar
    Dallas, TX
    Sexy!
    Nolan
  5. #1085
    Mechie3's Avatar
    Indianapolis
    My new lights came in. I made a slight error. The options were trim ring or no trim ring with a cost difference of a dollar or so. I went with the ring thinking if I don't want it, just leave it off. Turns out they mount differently. The ring style mount through the flange (visible screws) which are then covered with the trim ring (a good thing). It does mean you can't just ditch the ring. The non ring versions use three studs coming off the back of the body. Doh! I do like the quality of them though. They're marked for street legal use in Europe so they're not the typical Chinese scrap market stuff.
    The good: The rings add a good 1" to the total diameter. I'll likely make them black chrome, the silver is too blingy. For an F12 or F458 inspired rear it should work nicely.
    The bad: As is the bigger light is too big to replace the red FFR light as a drop in. Didn't check the smaller one.
    Large Light
    Upper left: Small light, brake and reverse
    Upper Right: Small light, brake and amber blinker
    Middle: same large light as photo above
  6. #1086
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Did you think about cutting the light hole open in the body and back mounting them to hide the ring?
  7. #1087
    Freeport, ME
    I was thinking of continuing my CF theme with a thin piece of CF covering that whole expanse in the rear with the lights mounted from the back. I like the sequential operating blinker approach, should be fairly easy with LEDS
    Dan
  8. #1088
    Mechie3's Avatar
    Indianapolis
    Hello Wayne,
    No, I hadn't. I was going to attempt to make a replacement back panel, so the ring might help me there. They do sell a version without the ring. I was just hoping I could get both versions in one (ie: remove the ring and it looks exactly like the non ring version...doh!)
    Dan,
    I should wrap the rings with CF.
  9. #1089
    Senior Member D2W's Avatar
    Spokane, WA
    How do you do black chrome?
    I can do anything with enough time and money.
  10. #1090
    Mechie3's Avatar
    Indianapolis
    Rattle can. lol. It's just a coated plastic piece as is anyways. It's more of a glossy dark gray.
  11. #1091
    Denver, CO
    You could probably tint over the chrome.
  12. #1092
    Member Ellimist's Avatar
    Salt Lake City, UT
    Lights really look good! and the CF wrap sounds great. PS, sent you a PM with an order list.
  13. #1093
    Senior Member R.Spec's Avatar
    Portland, Oregon
    All these parts just make me go woof! Love the titanium. I am going to try and replicate that shifter setup!
  14. #1094
    Mechie3's Avatar
    Indianapolis
    Thanks!
    I posted these to facebook, but forgot to put them here. I played with the lights at work a bit. They're plenty bright, not some cheap crap even though they came from a factory in china. They're not DOT marked, but they are marked for European use (which is very similar to DOT/SAE). It's one reason I got them.
    I was happy that the red portion has two levels, one for lights on (running lights) and one for braking. The lights are either brake/reverse or brake/signal, you can't combine the signal and reverse into a single light. You'd either need to have two lights per side or get a single center mounted reverse light. All photos were taken in a well lit office, my phone just auto compensated for the brightness of the lights (look at how dark my hand or the desk top is relative to the light output).
    Chrome ring removed. It twists to unlock and then pulls straight off.
    Reverse:
    Running Lights:
    Brake Lights:
    Turn Signal:
    Brake and Turn Signal:
  15. #1095
    Exeter R.I
    Nice!
  16. #1096
    wallace18's Avatar
    Trenton, Florida
    Very nice. How close in size are they to the FFR units?
  17. #1097
    Mechie3's Avatar
    Indianapolis
    I'll have to measure. With the chrome ring, the larger light is too big. Not sure about the smaller one. I have to measure the FFR ones as I don't even know what size those are.
  18. #1098
    QC, Canada
    Maybe they could just replace the FFR big reds (nope, those big reds are not Porsche calipers) so that we have our turn signals using yours and the smaller FFR ones for reverse only (instead of turn and reverse).
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  19. #1099
    Mechie3's Avatar
    Indianapolis
    There is a smaller version of these light available. Instead of the black ring (hidden by the chrome ring) it mounts from the rear (like the FFR lights). These are slightly undersized (by about 3/4"?)
  20. #1100
    QC, Canada
    Yes. These could be a good drop-in replacement of the FFR ones. Would not physically change the look, but once lit up (litte up, light up, lightened up, whichever you use) it would look cooler with the light ring when braking or at night.
    Will you test fit them after the larger ones you are working on now?
  21. #1101
    Mechie3's Avatar
    Indianapolis
    I'll have to buy some. I only have the ring versions at this point. I was going to go ferrari challenge grill style.
  22. #1102
    Mechie3's Avatar
    Indianapolis
    Made a new mount for the front of the AWIC. The other version I had didn't give enough clearance for non-clocked turbo versions. This version weighs 2.5 ounces. I need to make a slight modification to one section to make it easier to bend. Even without welding it up it's decently stiff. Once it's welded it'll make a nice strong box.
    Tight fit!
    But it clears!
  23. #1103
    Portland, Oregon
    I just want all those cool pieces to put on display in the front of my shop. Even though I have no need for them. >.<
  24. #1104
    Salt Lake City, UT
    Looking good! Just another reminder of my PM with a big order for parts ;-).
  25. #1105
    Salt Lake City, UT
    Quote Originally Posted by Ellimist View Post
    LOL, nevermind, looks like it's my bad - apparently I need to set up my notifications so I know when I get a PM.....
  26. #1106
    Mechie3's Avatar
    Indianapolis
    . No worries.
  27. #1107
    Senior Member FFR-ADV's Avatar
    NH
    Tight fit!
    But it clears!
    Looking great!
  28. #1108
    nkw8181's Avatar
    Dallas, TX
    That looks clean.
    Nolan
  29. #1109
    Jul 2012
    Encinitas, CA
    Quote Originally Posted by nkw8181 View Post
    That looks clean.
    The bracket, yes; I want mine! Craig's slave cylinder... eh, not so much.
  30. #1110
    Mechie3's Avatar
    Indianapolis
    You gotta problem with my slave cylinder!?! How bout we take this outside!
    Machining two more of these (with slight mods) after work today to send out to the two testers.
  31. #1111
    Jul 2012
    Encinitas, CA
    Naw, just spoiled by my nice, clean CA donor!
  32. #1112
    Hey - somebody has to come up with a hinge kit for the engine cover. What with the rear cover having to be open, vertically lifting the engine cover off the pins and the awkward size and shape of the engine cover, it is going to be almost impossible to remove the cover without help. How do you check engine oil etc. if you are alone in your garage?
  33. #1113
    Mechie3's Avatar
    Indianapolis
    That's further down my list. I need to finish a set of uprights for a local guy first so he isn't hung out to dry when autocross season starts.
  34. #1114
    I can't wait! Engine cover hinges are likely to be big sellers.
  35. #1115
    Mechie3's Avatar
    Indianapolis
    I'm sure they will be, but I have other promises to keep first. I'd hate to be the reason someone misses an event or two because I promised them critical parts for their car only to miss delivery because I was busy making other stuff.
  36. #1116
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    What would be really cool is to have something that caused both the trunk and engine cover to swing open as a unit. It could be hinged at the back or on the side even, and then a quick release of some sort on the hinge that would allow you to remove both pieces as one piece, after they were fully vertical and easy to hold onto. Not 100% sure this would work..... and would depend on the weight of both pieces together (I feel like they are pretty light though), but it sounds good in my mind.
  37. #1117
    Jul 2012
    Encinitas, CA
    Like this?
    Erik Treves did it in one of the first builds here.
  38. #1118
    anderson
    cool looking bracket great job!!
  39. #1119
    Mechie3's Avatar
    Indianapolis
    Don't look too closely at the welds, but this is one of two of the AWIC integration kits (for lack of a better term) going out to the product testers. I'm an aluminum welding noob and it was -4F outside in an unheated garage when I was welding. Brrr! For production pieces I've retained the services of my friend who used to weld for both a company that makes aluminum racing radiators as well as was the lead fabricator for the two seater indy car. It'll save me time, money (I scrapped probably 1/3 of the parts), and look nicer. This kit is everything that I will supply to fit the off the shelf frozenboost components.
  40. #1120
    Mechie3's Avatar
    Indianapolis
    I finished machining the first of two uprights. It's not 818 related so I made a separate thread that shows each step required to make it. Thought some people would be interested.
    http://thefactoryfiveforum.com/showt...121#post190121
