Thanks Thanks:  9
Likes Likes:  99
Page 34 of 48 FirstFirst ... 24323334353644 ... LastLast
Results 1,321 to 1,360 of 1908
Thread: Mechie3's 818S
  1. #1321
    Mechie3's Avatar
    Let's see if this works.
    Edit: it did. Click pic for link to video.
  2. #1322
    Leesburg, VA
    very nice!
  3. #1323
    May 2013
    Greenbelt, MD
    Wow, that is pretty. Nice work.
  4. #1324
    Mechie3's Avatar
    Thoughts: It's very direct, notchy, but positive feeling. I attribute the notchiness to the transmission itself. It feels like I'm shifting directly at the transmission as I can feel all of the detents clicking. The lever itself is a little short. I need more mechanical advantage and more shift knob travel.
  5. #1325
    Mechie3's Avatar
    Just some minor updates. Last weekend was spend autocrossing Saturday and Sunday (both Indy points events). Didn't take top PAX or FTD either day as it was a divisional event so more people and some very talented out of state drivers. 8th overall on Saturday, but only .5 away from the winner (who is 5 time national champion). All top ten were separated by less than .7. Sunday I was 10th overall. The good news is I'm still solidly in the lead for overall PAX for the year.
    My 7' shift cables came in. I think I'm going to use these. They'll wrap around the engine instead of over it. The change in feel is negligible if noticeable at all but the routing is much easier with less chance for the cables to get chewed up over time. Plus, thinking ahead, if I offer the shifter and the rear mechanism for those that keep the AC, the 6' cables wouldn't have worked well.
    cables will follow the AWIC lines
  6. #1326
    Freeport, ME
    I never tried my 7 foot cables around the engine... Hmmmm
  7. #1327
    Feb 2014
    Asheville, NC
    In the bottom left on the picture...what's clamped loosely to your axles near the coilover mount? Looks like rubberized clamps, anyway
  8. #1328
    Kirkland, WA
    I was looking at a 818 last week that also ran the cables around the engine and not over, looks like I will wind up doing that (as mine a way too tight now), what lengths did you wind up using for both cables ?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  9. #1329
    Mechie3's Avatar
    Pearldrummer: CV boot clamps that are just sitting there unclamped.
    FFRspec72: I used 7 footers for both and used different length adapters (threaded tubes) to accommodate the differences in mounting points on the shifter and mechanism. They're seastar solutions CCX43007 Xtreme cables. Took a month to get them in. I experimented with 6' cables in the meantime.
  10. #1330
    Mechie3's Avatar
    Clocked my good turbo today. Went much smoother than when I first did a test on a junk turbo. It helps that I knew what to do, just had to go and do it. I took photos of every step and did a writeup. Just need to add the photos to the writeup and then I'll post it here. The hardest part is getting the snap ring out which, with a good pair of snap ring pliers and a good grip isn't terrible.
    This is the clocked version that I developed with Bob'n'Cincy's help. The previous setup I had looked better (1 less bend) but the clocking bracket was much longer and not as strong. The compressor nipple also interfered with the TGV sensor (for those keeping TGV's).
  11. #1331
    Harley818's Avatar
    Vancouver BC
    Looks good Mechie. Looks better than mine with the shorter hose run.
    How are you making out with your shifter brackets group buy?
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
  12. #1332
    Mechie3's Avatar
    I need to update the models to make them less expensive and then send them out for quote. A few pieces ended up being more overbuilt than they needed to be.
  13. #1333
    Aotearoa (New Zealand)
    Ah this is epic!
    please tell me I can afford this.
    Maybe you could offer the kit in multiple options? ie
    1- Full kit (for the deep pocketed)
    2- The rear components on the transmission (just add MR2 shifter)
    3- Shifter (for looks)
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
  14. #1334
    Mechie3's Avatar
    That's the plan.
  15. #1335
    nkw8181's Avatar
    Dallas, TX
    Nice! Could it tie into the ktune shifter?
    Nolan
  16. #1336
    Mechie3's Avatar
    Not directly. The bell crank operation would need to be reversed. It might be as easy as flipping it upside down and having a longer extension on it, but i'm not sure.
  17. #1337
    Mechie3's Avatar
    No progress on the car. My favorite tree snapped in half 3' off the ground in a storm Monday night. Ended up having to take 2 feet off the top piece but was able to get it back on the base and attempt to graft it back together. Took me almost 5 hours but it's splinted and sealed with wax. Time will tell if it will live. I've been training it and pruning it for the last 6 years and it was about a 10 year old tree when we bought it so I kinda like it.
    Anyways...
    I did buy the rivnut tool from Amazon. Much easier to use than the pop rivet style tool. Can't fit in all the same tight places, put for everything else it's nice. Need to make a custom arbor for 10-32.
    Here's something that I made for Wayne @ VCP. Wayne came up with the idea and the external dimensions and sent me a sketch and asked if I could make him a set. All I did was add the fin geometry, which is nothing special, just matches the geometry of my other louvers. They mount to the rear top corners of the fenders to vent the air in the wheel well LeMans style.
    First shot are the real parts. Second shot is a paper printout to check fitment.
  18. #1338
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Looks great Craig, can't wait for them to show up!
  19. #1339
    Mechie3's Avatar
    I think you should have them tomorrow. Dropped them off at the PO Monday on my way home from work.
  20. #1340
    Who's going to sell these? VCP or ZdBM?
    I'm in for a group buy or a non-group buy I'm in too.
  21. #1341
    Mechie3's Avatar
    I sent them off to the shop for quoting today.
  22. #1342
    Administrator
    Enterprise Alabama
    They will be a Zero dB part Frank, i requested that Craig design them to match the louvers he already sells as i do not want to overlap his products
  23. #1343
    Mechie3's Avatar
    I got quotes back. I thought they were high until I realized I forgot to multiply by 2 when I told Wayne what the material was. lol. Doesn't matter anyways because he sent me too much $$ because he's a good guy like that. Maybe he's better at math too.
    If you got 5 people interested they'd be $60 a pair. 6- 10 people would be $45 as my cost goes down a similar amount. If you're interested I can start a thread.
  24. #1344
    Clovis, Ca
    Count me in. I love cutting more fiberglass
    Thanks- Chad
  25. #1345
    Denver, CO
    Given cooling issues, I am in for cutting more fiberglass as well. Any pictures to give better idea of new look?
  26. #1346
    Denver, CO
    This is exciting Chad!! Does this mean you are going to stick around in 818 community a bit longer?
  27. #1347
    Mechie3's Avatar
    Quote Originally Posted by bbjones121 View Post
    The whole fender vent is just a scam to try and keep Chad around a little while longer.
  28. #1348
    Senior Member SnyderJD's Avatar
    Interested
  29. #1349
    Denver, CO
    Haha
  30. #1350
    Clovis, Ca
    I have a couple interested parties, but the car would be worth more running right.....
    Mechie- how about some of these in a pattern for the top flat portion of the rear humps? I have been wanting to do something up there to vent.
    Thanks- Chad
  31. #1351
    Anyways...
    Gah! too many... cool... parts... for wallet... to survive... sigh
  32. #1352
    Mechie3's Avatar
    Chad, I can whip something up.
  33. #1353
    Freeport, ME
    Must.... stop.... project... creep...
    Craig, I love the fender vents, add two small radiators and that gaping maw can be plugged and used for storage! Long term for sure!
    I NEED those side vent scoops... any update?
  34. #1354
    What? That's money found in a dumpster, I'm in! I mean not in the dumpster, but in the group buy.
  35. #1355
    Mechie3's Avatar
    How's this for project creep? Guy I bought my fmod from made me an offer. He's going to pick up my car, tow it to nationals, warm tires for me, and provide brand new sticker hoosiers. He even said if I'm short on time, I can fly in (like I did when I drove his car in 2012). So now I'm refreshing a few bits of the F500 to go to nationals. lol. Nothing like more distractions.
    No update on side scoops.
    Frank, where are these dumpsters with money? I'd like to do some diving.
  36. #1356
    Clovis, Ca
    He was probably talking about my gold leafed 818R turd.
    Thanks- Chad
  37. #1357
    total bummer. I feel for you, I have a favorite tree in my backyard but the two recent hurricanes have taken it's toll. It sucks, no way to start over at this point.... instant gratification when it comes to trees is expensive.
  38. #1358
    Mechie3's Avatar
    Yeah, unfortunately. I read a Chinese proverb once about trees that said "The best time to plant a tree was 20 years ago. The second best time is now". One downside of living in a new housing development that used to be a cornfield is a general lack of mature trees.
  39. #1359
    Freeport, ME
    Have fun at Nationals, sounds like an offer that you can't refuse!
  40. #1360
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    We should meet up at nationals! It'd be great to meet you.
    Tamra
    First autocross 3/29/15
