Thanks Thanks:  9
Likes Likes:  99
Page 44 of 48 FirstFirst ... 344243444546 ... LastLast
Results 1,721 to 1,760 of 1908
Thread: Mechie3's 818S
  1. #1721
    Mechie3's Avatar
    This is a (designed by me) Boyd tank. Filler is at the top and higher than everything else. I'm guessing it's that way because they took the '33 tank and made it work for the 818. Frame openings dictated the location on the existing tank vs adding a new top piece.
  2. #1722
    But if the boyd tank and the FFR tank both fit without frame mods - that doesn't explain why FFR put their filler so low, no?
  3. #1723
    Mechie3's Avatar
    The boyd tank builds up above the stock height. It requires a separate piece to be fabricated and welded to the top of the tank. The new piece is square so has more bends and welds vs just moving the location of a round filler. The round piece doesn't need any bending or shaping, just cut some tube and roll a bead. Likely a cost measure. Mfg can make two tanks 95% the same and jsut weld the fill next on in different places.
  4. #1724
    Mister Craig, did you see that your front fender louvers, designed for the old nose, fit a little different on the new nose? I think it's ok but how should they fit best, do you know?
    Like this:
    Or super close to the headlights?
    Or should you design slightly different ones for the new nose?
  5. #1725
    Senior Member Blwalker105's Avatar
    Is it possible to reverse them and carefully re-bend the slats? Looks like the contours would match well and you could move them much further rearward if you wished.
  6. #1726
    Freeport, ME
    Like this:
    you have them backwards, wide edge forward will fit the space
  7. #1727
    Yes it does fit better with wide edge forward. I'm testing which side up looks better, now.
  8. #1728
    Mechie3's Avatar
    What do you mean what side up looks better? Front and back should be identical (though one might have a nicer finish as when the other side is finished it tends to scratch the underside).
  9. #1729
    No that's not what I meant, but it's ok I got responses on my build thread.
  10. #1730
    Mechie3's Avatar
    Been too busy working (real job, 0db, car, getting ready for baby) to post updates.
    I..."massaged" the front end and got it to fit better. There's still areas that the meticulous engineer inside me dislikes, but it is what it is. The subframe rubs against the driver side fog light recess (for lack of a better term). I'll need to grind off the edge. The passenger side fits nicely ins the little pocket/rib next to the recess so clearly the body and/or the frame isn't straight. Can't quite get the leading edge of the hood straight. If you look at the FFR showcars, they're the same way. The passenger side fender doesn't line up right with the hood. It's certainly a manufacturing problem (I'm sure the design is fine in CAD, they just can't make real parts match the CAD).
    Driver side hood/fender. Decent alignment:
    Passenger side. Hood is pulled back (same as FFR showcars):
    Driver side hood/fender/windshield. Note position of hood tip relative to triangle on the fender (also note the fender line actually bends inwards while the hood continues to bend outwards making for an odd mating of convex and concave edges):
    Passenger side hood/fender/windshield. Confirms what we knew that body isn't symmetric.
  11. #1731
    Mechie3's Avatar
    Now, back to things I'm good at. Precision machining parts that fit together nicely. I don't like the plastic overflow tank and don't want to pay $70+ for one. Solution? Make my own. Machinist is out for a week so I took advantage of the open time on the CNC.
    Top and bottom caps. The recess in the bottom cap reduces weight and makes it so if gunk builds up in the coolant tank that it settles in the recess and doesn't get pulled into the engine as easily.
    Tapping top cap:
    Test fit. Side bungs are for a sight level:
    Welded together. Not award winning beads but not bad for an engineer teaching himself TIG through youtube and google. lol. I'm mostly happy it doesn't like complete garbage and I didn't burn up several hours worth of machining.
  12. #1732
    Mechie3's Avatar
    Another inside view of the bottom of the can:
    Started making a cap for the coolant tank. Used titanium, of course. Cut the one side on a CNC lathe and threaded it. Chased the threads with a die to make sure they were good. The die holder is about 3' long end to end.
    Took several chases with the die to get it to fit smoothly. Titanium likes to bend and not cut so tools like dies tend to temporarily deflect the material instead of cutting it.
    Switch panel mounted:
  13. #1733
    San Diego Ca 92106
    Aren't you painting your car? The hood issue can be fixed if you're painting or even if your willing to color match the gel coat. It's a lot of work for sure but possible.
  14. #1734
    Mechie3's Avatar
    I will paint or something eventually. I know it can be fixed. It just adds time (I'm already three years into a 200 hour build ), I have another project showing up in late october/early november that needs to be ready for autocross season in late April. I've never done fiberglass so it'll take more time than the knowledgable person, or I could pay (which would be $$$). Originally these were "paint free", which I interpreted as "bolt on". It was certainly an appealing part of the puzzle as the metal work is something I can do.
  15. #1735
    San Diego Ca 92106
    Yeah I was hoping for "paint free" too. But at least that fix won't keep you from driving the car. Working with fiberglass isn't really that hard, just time consuming (sanding).
  16. #1736
    Mechie3's Avatar
    Did some lunchtime work. Cleaned up the backside of the cap and bored out the inside. 1/4lb is too much for a cap that is only titanium to be bling bling. Aluminum would have been so much easier and faster, but less colorful in the end. Gotta drop that weight!
  17. #1737
    Senior Member AZPete's Avatar
    Incredible work. I sure wish you lived next door.
  18. #1738
    Yeah girls like that. I mean, your car is a girl, right.
    That's odd, I have the opposite situation, the driver's side is just a little longer, I can easily sand off the difference or add gel coat to the pass's side, but in your case the pass's side is longer. Have you tried centering the nose insert to the frame, then fitting the pass's fender right and then the driver's? Or maybe it's your frame, there are too many differences with my panels and other new nose's panels I've seen.
    Hum I think there is good stuff to do here, little adjustments to follow the lines and it should look good.
    That's a lot. You could cut the hood but it's easy to see the change in angle. Maybe adding gel coat on the top of the fender to match the hood's edge but where's your door fitting?
  19. #1739
    Mechie3's Avatar
    That was the first approach I took and you saw how well that turned out.
    I put a straight edge on my fender and it clearly goes from a convex shape most of the way and then switches to concave right at the very end for the last couple inches.
    Milled out a 5 lobe pattern on the CNC. First time milling titanium on the CNC so was a bit nervous:
    Then hit it with a torch. Perfect color! Holding it with tweezers because at this point it was still hot enough to leave a permanent imprint on your hand.
    After wasting time listening to two VP candidates talk over each other like middle schoolers I went in the garage and mounted it up:
    Need to get fittings for it and polish it up and it'll be finished.
  20. #1740
    Hey Craig. I PM'd a question for you. Please reply. Thanks, Tom.
  21. #1741
    San Jose, CA
    That turned out awesome, well worth the effort!
    Aluminum can change color like this? I thought it was only titanium and maybe other rare metals.
  23. #1743
    Mechie3's Avatar
    Well...that's because:
    and
    It's titanium. lol. Just giving you a hard time. It's probalby about $200 worth of titanium. I couldn't cut it with the band saw so I used a 3/4" mill to cut a piece off the end. (that alone probalby wasted $30 worth of titanium). But, when you have almost 12 feet of 2"OD titanium you got for free, you don't really care.
  24. #1744
    That sounds like 3 set of axles to me.
  25. #1745
    You son of a... lolll Good thing you started on that, hopefully you'll come up with great products we can benefit like the alu ones you already did. Maybe a full titanium exhaust?
    Sorry I missed it when you wrote "titanium" in your other posts, I guess I was too impressed by the pictures!
  26. #1746
    Mechie3's Avatar
    I'm (mentally) working on a simpler design for that overflow tank. I have a bunch of milled features, but I think it can be done with laser cut puts (much less costly in low volume).
  27. #1747
    Hey man, have you tried fitting the old nose and see if it has the same issues as the new one? If yes then we could most probably think it's the frame.
    But that is only if you still want to know whether it's the frame or panels...
  28. #1748
    Mechie3's Avatar
    I had the old front end on at one point. The fender to bumper was different at the hood junction and the hood had a similar issue with the one side being slightly off.
  29. #1749
    Mechie3's Avatar
    My latest masterpiece. Lol.
  30. #1750
    south-central CT
    Nice! Congratulations!
  31. #1751
    Reno, NV
    Congrats!
    818R Build date 10/31/15
  32. #1752
    Edmonton, Alberta
    Congrats! This is your second right? A lot more work for dad when there's two, ask me how I know, lol.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  33. #1753
    Congratulations!!
  34. #1754
    Encinitas, CA
    Congrats, Craig!
  35. #1755
    Very cute, Craig. Congrats!
    Did it come with just the one wrench?
  36. #1756
    Congrats Craig!!!
  37. #1757
    Rochester, NY
    is it a 10mm?
  38. #1758
    Quote Originally Posted by 305mouse View Post
    is it a 10mm?
    No Craftsman 14mm, He lost it last winter. Must have fallen out of his pocket.
  39. #1759
    Mechie3's Avatar
    Yes, second kid. Still on my first kitcar but managed to make 2 kids in that time. Lol.
    Just the one wrench. Bob was close, 1/4" craftsman. Perfect size for the wilwood caliper bleeder screws on my Fmod.
  40. #1760
    Apr 2015
    Andover, MA
    Nice job Craig! Some are born with a silver spoon....some with a chrome vanadium steel wrench! I hope mom and baby are resting comfortably.
