Results 1 to 7 of 7
Thread: Gas Pedal Mounting
    Fresno, CA
    Gas Pedal Mounting
    Any photos of how you builders mounted the FFR supplied gas pedal in the Hot Rod? I am thinking of putting a block behind it to bring it out further into the footbox and allow for more travel. It seems that if I mount it up to the firewall that the top arm hits the squair tube and limits travel.
    thanks,
    Doug
    Stillwater, NY
    The arm on my pedal is fully adjuatable - is yours not?
    Fresno, CA
    I will look tomight when I get home from work.
    I mounted mine to a panel I produce and incorporated a throttle stop.
    Senior Member Arm7419's Avatar
    Sedona Az
    Here is how I mounted my gas pedal and a stop.
    Chuck
    Mk1, MK3, Hotrod, Gen 3 Daytona Coupe, RF GT40
    Hang Up and Drive
    Hi Chuck,
    Do you have a photo album on line ? You do some really cool stuff that would be neat to see.
    Sedona Az
    No I don't. Probably something I could work on.
    Chuck
    Chuck
    Hang Up and Drive
