Results 1 to 3 of 3
Thread: Shim Kits In Stock
    San Diego
    Shim Kits In Stock
    Just wanted to let GTM owners/builders know that I currently have 10+ shim kits available.
    You can see/order them here:
    http://www.myraceshop.com/Alignment_Shims.html
    For those that don't know what these are or will do for you, here is a short explanation.
    These Alignment Shim Kits have been developed to do three major things for the GTM builder.
    1) They offer a more positive "lock in" of suspension adjustments as compared to the conventional GM "cam bolts". The cam bolts have been known to slip out of adjustment when stressed heavily, and since every GTM is capable of overpowering the cam bolt setup in stock form, for this reason alone, the Alignment Shim Kit should be a "must have".
    2) They offer easy adjustability by giving you precise locations when changing shims. This means that an adjustment can be made without having to break out the alignment tools or visiting an alignment shop. Very useful if doing adjustments at a track on a race weekend.
    3) They offer the builder the ability to GET MORE CASTER than the stock cam bolt setup allows. This is very beneficial in that it is a known issue that the way the Corvette suspension is mounted on the GTM frame does not allow for enough caster to be adjusted into the front suspension. These shim kits allow 3.5+ degrees of caster to be achieved on a GTM when combined with slotted upper arm mounts.
    These shims are all laser cut 3/16 steel and are precision parts. They are color coded for ease of identification, and also have an indexing notch on them so that fitment, even into a location that can't be seen, is easy and accurate.
    Any questions about the Alignment Shim Kits or any other parts that My Race Shop sells are always welcome.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    San Diego
    Here's a pic of what is included.
    www.myraceshop.com
    GTM solution kits
    MA
