to pass State Patrol
Mk 3.1 #6945
I took a quick read through this (http://www.moga.mo.gov/statutes/chapters/chap307.htm) and it does not appear that MO requires wipers at all. But, I would make a call to your local State Patrol office and ask. Be sure to write down the date, time and who you talked with (including badge or ID number.)
Ray
BigLeo,
I went thru the 551 inspection in 2006. I was worried but the question never came up. I had a copy of state regulation 11 CSR 50-2.230(1) which states wipers required when equipped by the manufacturer. My plan was to argue that I was the manufacturer.
Hope this helps,
Rob
No you do not. None on my car, and it wasnt questioned at Troop C or at the safety inspection.
great another issue i won't bother with, except now our posts are in the gulf region, whats up with all the changes i from MO you got to show-me
Mk 3.1 #6945
Haven't had wipers since '07 and just went through my 5th inspection last week with no problem.
