Is there going to be a hard top as an option? If so it would make a great daily driver.
I don't know. Maybe I should search to see if I can find you that answer......
Will STI parts work?
Trololololol
OP, Its been asked and answered many times. Same as the sti parts question.
You might want to check on Vman's profile page. Now recent posts are showing up there. I know he is working with FFR to develop something. You can probably see something related to the question you have. You can also do a search yourself. It works sometimes (not the best search engine). I have done better when I go to the particular subforum such as 818 and then search. Good luck. WEK.
Hard top? What a novel idea. Someone should suggest that to FFR
Rofl. Been asked several times. Just search next time.
It's just that the lines look so good on the 818 I can certainly see a design that would look as though it was part of the original package.
