0
Setting Brake Bias
So, I understand HOW (mechanically) to adjust the Brake bias on the MK4 (Pedal kit and Wilwood brakes from FF). However, what I'm looking for is a little guidance to understand how to know when I've got them set correctly? I'm sure it is a bit of set it, try it and see how it stops, and then adjust. However, I'd like some guidance towards getting it close in the first place. I'm not racing the car, but rather using as a "Summer Driver" but certainly want it set properly. Common sense tells me that you want more bias on the front brakes, so that they would lock up first, but again, not sure how to look at the bias adjustment bar and figure out where it should be set.
I have manual brakes, 15" wheels. Let me know if there is other info that is required to provide some guidance.
