Results 1 to 17 of 17
Thread: RE FFR Soft Top
    Member Lancaster Lad's Avatar
    High Desert, CA
    RE FFR Soft Top
    This question is for the owners that have the 'modified' soft top, zip out rear and quarter windows.
    Did you purchase all through FFR or order from FFR then contact Rod Tops to modify and pay additional
    or did you order directly from Rod Tops?
    I know this is a open car but I need some sun protection for my increasing bald dome.
    Thank you in advance for your time
    Cecil
    MKIV 8851 Complete LS3 376/480 4L70e Auto 2015 IRS 15" Wheels Rear Exhaust
    Ordered 2/25/16 Delivered 3/26/16 Still building 1/1/22
    Senior Member Jester's Avatar
    Hi Lad,
    I believe the only way to order is directly through FFR. Once you place your order, you will receive an order reference number. Then you contact Rod tops to add the zip out's etc in reference to your order number. Rod Tops are very professional and will turn your order around quickly so you will need to contact then as soon as you have your order reference number form FFR. The premium to is fantastic and very well designed. You will be happy with the enhanced creature comfort - it completly changes the driving experiece.
    Good luck
    15th Anniversary Edition
    Mk4 - 18 month build (4 hrs every Sat), received Aug 2011, titled & registered May 2013, final in paint Nov 2013 - Ferrari blue
    FRPP Crate Coyote 5.0, tko600, Moser 3 link, manual steering & 13" brakes, upgraded coil overs
    koolmat then dynamat then carpet in cockpit - very solid, no engine heat transfer to cockpit and no road noise
    bobl's Avatar
    Spicewood, Texas
    Seems like a good place to throw out a question I have. Are the corner windows and zip out windows an additional cost, or are they included with the FFR purchase price? If optional what is the ballpark cost?
    High Desert, CA
    Hi back at you Jester
    Thank you for the quick reply. I have heard nothing but good remarks on both forums about the FFR (Rod Tops)
    soft top. Looks time to call and spend money on the 'money pit' but I will put it to good use.
    To bobl
    I have no idea what the additional cost is, but like most items on my project it will cost what it costs. Unless
    someone reports first I will post my extra cost unless it is a trade secret.
    Just means less for 'the batman' for paint.
    Senior Member Crawleyscobra's Avatar
    They are an additional cost.
    I think I paid an extra $150.
    FFR6682 - received 7/30/08 - MK 3.1 complete kit, Forte built Ford Racing BOSS 427W(475HP/500lbs), TKO600, Power steering, Power Brakes, Hydraulic Clutch, VPM Front/Rear sway bars, Bump steer kit, SAI mod, 13"Front/11.65"Rear Mustang Cobra rotors w/calipers, NITTO NT05s - 255/40R17-Front, 315/35R17-rear,3.55 IRS.
    Visit my Blog: http://crawleyscobra.wordpress.com
    What was the time from order to delivery?
    Carl
    High Desert, CA
    carlewms
    I just got off the phone with FFR and was told my top will take 3 to 5 weeks. Have not received reference
    number yet so do not know current extra cost. I plan on quarter and rear zip out window and maybe color change from black.
    High Desert, CA
    to any interested builders
    Just contacted Rod Tops with my changes. Top will be ready by 2nd week of April or 6 weeks.
    The cost is $150 for each change item. For me that is $450 extra for quarter window zip out rear
    and changing color to tan/tan.
    bobl's Avatar
    Spicewood, Texas
    So to make sure I understand, the side windows are included with the top. Quarter windows would add about $150 to the price? Correct?
    Jax Beach, FL
    Side windows and storage bags are included.
    Quarter windows, Zip down rear window, and color changes are options.
    Here is how you do it:
    1. Order from FFR.
    2. Get your invoice number from FFR. This should be the same or next day at the most.
    3. Call Rod Tops, give them the invoice number, and tell them what options you want.
    4. Get brave, and drill a couple holes in your car.
    One tip for the zip down rear window. When you roll it down, roll a big microfiber towel into it, so that the towel is sitting on your paint. If not, the plastic will vibrate and scratch your paint where it touches.
    The top is a really nice piece. My wife basically won't go in the car without the top on. I am in Florida, so use it for sun protection. It has also saved me from rain a few times including a last minute hurricane move to a friend house.
    mcwho's Avatar
    DeBary - Florida
    IM interested in this top as well, the options look like a great way to go. I'll be following this post.
    Baghdad Bob
    Based on my APE hardtop experience I can't recommend strongly enough the zip out rear window. I never take my top off. The side and rear windows are temp dependent. W/ all the windows gone it is really nice being in the shade and the wind beating on the side of your head is reduced to about 40% strength. Footbox fresh air vents and a top w/o windows makes for reasonable comfort even at 90 deg as long as you are moving.
    High Desert, CA
    CraigS
    Just to let you know I dream of summer temps in the 90s. Normal summer temps here have 3 digits.
    Regarding the rear window. I know I said 'zip out' but I think remembering reading the window might just zip down only.
    Doesn't matter that much to me as CraigS says, any opening in rear will help with the air flow.
    Member Hotrod's Avatar
    Kankakee IL
    Any pictures of the modified top? I would like to see the windows and zipper window.
    Never drive faster than your guardian angel can fly.
    MKII 4393 Tangerine Pearl with white stripes. I try to change something every year because I believe a real hotrod is never done.
    Member JBMorrison's Avatar
    Quote Originally Posted by Hotrod View Post
    X2!
    pics located in the following link: http://thefactoryfiveforum.com/showt...emium+soft+top
    Member hayton55's Avatar
    May 2016
    Milton, Nova Scotia (summer)
    Hmmm, I just picked up my kit and called RodTops and added the zip out rear and quarter windows; since I did both additions at the same time it only costs $200 vice $300 ($150 for each)….the extra time required was only a couple of weeks from when it was originally anticipated…..
