Thanks Thanks:  2
Likes Likes:  3
Results 1 to 11 of 11
Thread: Fuel line routing
    May 2018
    Pinckney, MI
    Fuel line routing
    So I decided to run 3/8 line and AN 6 front to back. AN flex at the front, hard line in the middle, and hose at the rear.
    Here’s the lines attached to the Sniper and heading back to the firewall.
    Next, they run over to a gauge for reference.
    Run down the firewall
    I made a small bulkhead to mount a couple of fittings.
    Hardline fittings
    2EE27C39-A602-4BAE-A341-0377B01AC7EC.jpeg 60E7A027-1091-4662-910F-6CEDD1CA2F73.jpeg
    Routing along frame
    Rear bulkhead
    8C5197B3-F7C7-4351-A635-EC1F476B7C1B.jpeg A6BCA0DE-5A12-40BE-B9B6-688EDDED1F62.jpeg
    Around the tank
    So, any comments from the esteemed experts around here?
    - Peterh226 #1134
  2. Likes JOP33, Mrallsport32 liked this post
    Senior Member sethmark's Avatar
    Virginia International Raceway
    Looks great to me.
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
    Aug 2013
    Gatineau, Quebec, canada
    Nice work! I did a similar setup with the AN in the front and a combination of AN and hose in the back, this made for easy maintenance for the fuel pump and all underneath.
    Andreas
    Kingsland, TX
    Looks great, but I would suggest separating the hard lines. Using the side by side lamps for example or even just using zip-ties, just something to keep them from rubbing against each other. It won't take much time, vibration, and road grit to wear a hole in a hard line. It'd be sad to see your car go up in flames because of a hole in a fuel line.
  6. Likes peterh226 liked this post
  7. #5
    Nov 2015
    Elverta, CA
    Peter, I would suggest you rotate the tank outlet on top so your lines face more toward the front. With the body on you will have no way to get to those lines from the trunk or by removing the waterfall. I never thought I would have to fool with mine but I have ended up pulling the tank several times in the build process. You'll want to be able to check those fittings from the front. Otherwise it's looking great.
  8. #6
    May 2018
    Pinckney, MI
    Quote Originally Posted by Brave Salmon View Post
    If the lines face front, then they poke through the waterfall. I’m planning to make the waterfall removable anyway for service of the fuel pump and filters. Once the roll bar and top is in place, I’ll need to get back there anyway. I think I will trip the body flange in that area to give me a little more room.
    - Peterh226 #1134
  9. #7
    Dec 2019
    Peter, whose braided hoses are you using? I assume you are custom fabricating each one. Whose tool are you using to attach fittings to hose? Where did you purchase these items. I am building the 35 truck and working on fuel line routing. These photos are very helpful!
  10. #8
    Dec 2019
    Questions on set up
    AJT, I am building 35 Truck. Whose flexible hoses are you using? If you are making up each piece of hose, what tool are you using to connect fitting to hose.
    Thank you
  11. #9
    The F5 braided hose is available as summits private label. The OEM is out of Florida.
    Titled 2-28-20
    MkI.IV 2643k
  12. #10
    May 2018
    Pinckney, MI
    Quote Originally Posted by chuck35truck View Post
    Some braided hose came with the Factory Five Fuel Injection kit. Another length came with the Holley Sniper provided with the Blueprint engine. The ends were purchased from Summit. It all went together without any special tools.
    - Peterh226 #1134
  13. Thanks chuck35truck thanked for this post
  14. #11
    Aug 2013
    Thank you
    Hey there, the braided hoses (https://www.racetronix.biz/storeitem...e%2Drubber)and the AN end fittings I got from Racetronix, https://racetronix.com/products/, all the ends are slip on and tighten (https://www.racetronix.biz/storeitems.asp?cc=fitting), the only tool I bought is the wrench and the clamps for the vise (https://www.racetronix.biz/storeitems.asp?cc=fit%2Dtool) so as not to mar the fittings themselves as they are aluminum.
    For the heater hose, I used regular 5/8" rubber hose and added on a braided cover, I also had the proper size shrink tube to help clean up the ends as well. Basically used what I had and tried to make it look better without spending a ton of money. The bulkhead fittings are real convenient for going through the firewall.
    Have fun!!
    Andreas
  15. Thanks chuck35truck thanked for this post
