FFR Cobra IRS Parts
Parts to build FFR Cobra IRS. I started a related project using FFR design, but cancelled.
- FFR Toe Links (new)
- FFR Lower Control Arms (new)
- FFR Pumpkin Bushings (new)
- FFR Various bolts (new)
- Ford aluminum third member (7,000 miles) with new 3.55 gears, bearings and Traction lock, with DS adapters.
- 2014 Mustang GT rear brakes, disc low mileage (11.8in) and calipers (new). Will work with 2015+ spindles. This setup is smaller for more wheel clearance.
$250 for control arms and toe links.
$500 for differential with DS adapters.
$150 for brakes.
Located in Wash DC area and could deliver nearby.
Missing upper control arms, and all frame mounts. I have axles, but they're a different length and not sure if they'll work, but CV joints are good.
KCaniglia
No takers ???
set you a PM
Only LCA's and Toe Link's left!
