Page 2 of 2 FirstFirst 12
Results 41 to 75 of 75
Thread: Engine cover hinge?
    Yes. I want them, although will probably have to modify some to clear my engine hood brace and spare tire mount. Tell me how to order.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Mike,
    Presuming one doesn't connect the engine cover to the front of the trunk insert, do you think your hinges will work with the new trunk?
    Larry
    Larry. I picked up a trunk insert yesterday and am working on getting it installed. Seems like it will work just fine with some minor modifications. In fact my hinges will most likely be the front mounting point for the insert.
    Port Charlotte, FL
    PM sent Mike.
    Henry
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Cool! Let us know how it works out. I'm definitely interested.
    Larry
    Ok I got the FFR supplied trunk insert installed. There is very little modification needed to use my hinges. The bigger problem is that factory Five has you screw the front edge of the insert to the lip on the engine cover. That will make checking your oil etc. kind of a pain. Heres where my hinge helps out. I redesigned the hinge so that it has a mount built in to hold the front of the trunk. Everything worked out pretty well. I hope to have all the materials in stock this week and start shipping hinges next week.
    Here is a picture of the actual insert. It comes in three pieces and cannot be installed assembled. I suppose if you removed the rear bumper you could get it in.
    Here is a picture of the modification needed to clear my hinge setup. I also trimmed this flange back quite a bit as it is no longer needed to bolt on the insert.
    And here it is installed.
    Here is the new hinge bracket machined to accept the insert mount.
    And finally installed in the car.
    Everything bolted up nicely and feels pretty sturdy
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I like it. I think I'll be ordering soon.
    Larry
    The first round of hinges went out yesterday and today. I still have a couple more sets left in this run.
    I got my set today. Very nice looking piece!
    Mar 2014
    Silver Spring MD
    My hinges arrived yesterday. Very nice. Thank you.
    The only thing I don't like about my hinges is that the 1/4 20 button head bolts fixing the hinges to the frame are very short - only catch by a thread or two. I will be sourcing longer bolts.
    Really? I wonder if I send the wrong ones? If anyone needs longer ones, just let me know.
    Harley818's Avatar
    Vancouver BC
    Mike, I'll PM you. I'm interested in a set.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    QC, Canada
    I don't think the opening in the rear lid (has mesh on this one pictured) will have any benefits, now. Unless you put someone (alive) in your trunk, like The Transporter?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    I plan to run another 20 sets of these if anyone else would like to order them.
    Clovis, Ca
    I'm jealous. These are so cool and would be perfect at the track. But my wing mount is in the way.
    Thanks- Chad
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I got mine today and installed them this evening. They fit perfect, were easy to install and Mike included good directions like always.
    Larry
    May 2013
    Colombia
    Hey Mike, are you still selling these?
    I am. They are now listed on my web site. I am currently running another 10 sets with 3 spoken for.
    Mar 2014
    Hingham, MA
    Just want to be sure I am one of the three.
    Ivan
    Ivan. Yes you are
    Senior Member Quiny's Avatar
    Massachusetts
    Don't forget me Mike, after seeing these in person I will have to have a set. They do such a good job of stiffening everything up in the back and holding the engine cover at the perfect height.
    Quiny. Your number 3
    Denver, CO
    where can I order?
    www.replicaparts.com or just PM me your address and I will put you on the list. They are $187 shipped anywhere in the US.
    Massachusetts
    Michael I just Sent you a PM. Looks like a quality set. Count me in.
    Davis
    Thanks Davis. Your #4 of 10 on the list. I will be offering these in black powder coating for anyone interested. It will be an extra $25.00 Will post pics of them soon.
    Massachusetts
    My check will go out Sat morn. I don't need powder coating but may buy the FFR trunk insert later.
    Thanks Davis
    Kirkland, WA
    Mike, what is the distance from center of the shock tower brace to where the base of the hinge mounts on the tower ?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Next time my car is off the lift I will check. Its the same distance as the spacing on the engine cover humps though.
    Frankfort, IL
    Tony, for reference, I installed the hinges onto the engine cover first, made sure my engine cover was in place where I wanted it, and then swung the first hinge down to the frame wherever it wanted to land naturally. Mounted it up, and then used the center to center distance Mike is referencing (I actually measured from center to center on the mounting plates) to be sure the hinges were parallel to each other.
    Due to all the variables in installing the bodies, I imagine the measurement you referenced won't necessarily be meaningful.
    The tolerances in the hinges will allow you to do what bill said. Just mount them to the engine cover once it had been fitted. They just swing them up to the frame, mark the holes and drill. Install the bolts and your done.
    The next run of hinges are done and will go out in the morning. I have about 5 sets that are not spoken for if anyone wants a set right away.
    Thanks Mike
    Mar 2014
    Silver Spring MD
    Thanks again for this excellent part. The hinges went on easily, and if a novice like me can do it, anyone can. The cover is currently held up by an old curtain rod. I was able to purchase a Fiero support, as recommended earlier. It is surprisingly similar to the one in my 1965 Corvair, which I needed to sell to take on the 818 project. Any suggestions on mounting the Fiero support? Attachment points?
    I will take some pics and measurements next time its off the lift.
