Thanks Thanks:  10
Likes Likes:  65
View Poll Results: How to finish the mesh panels?
Voters
57. You may not vote on this poll
  • Gloss Black
    47 82.46%
  • Unfinished Aluminum
    10 17.54%
Page 8 of 16 FirstFirst ... 678910 ... LastLast
Results 281 to 320 of 619
Thread: mikeb75's build thread
  1. #281
    Denver, CO
    Quote Originally Posted by mikeb75 View Post
    they look like this:
    They seem to have been included because FFR changed to some nice pull cables to open the latch/striker which don't work with the original door hardware. They're SMALL -like 1 finger pull small.
    I was able to use the original door handles and hard lines without much issue; though there is a small fitment problem with the Subaru handles.
    Sorry, I meant the nicer ones that azpete bought. I received my plastic ones the other day also.
  2. #282
    QC, Canada
    Those are the new FFR inside door handles?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  3. #283
    So Friggin’ Close
    Finishing plasti-dip on the bonnet and going over some problem areas. I'm pretty happy with the fixability of plasti-dip. I put about 3 coats over the problem areas on the front fenders and they look pretty good. If you look closely there are some straight lines where I cut off the worst 'dip areas and didn't blend between old and new, but just the new spray areas look very good.
    Put trim on the bonnet to reduce rub against the fenders (still a little too tight, need to reposition passenger slightly and patch dip- again) and in the cut-outs for the grills.
    I have the mesh rough cut and painted, but got side-tracked working on a stay for the bonnet/hinges. The hinges appear to be pulling the riv-nuts out of the front bar so the bonnet is looking unsafe when open.
  4. #284
    Senior Member AZPete's Avatar
    Very nice, Mike. You are making me like matt finish. It looks mean!
  5. #285
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Looks cool
  6. #286
    I was just reading about plastidip and watching a bunch of videos a couple days ago. Looks like pretty cool stuff, but I saw a picture of one that looked like it started to disintegrate when the guy tried to strip it. Also looked pretty thin, so it wasn't obvious whether it was too much time in the sun or just not enough coverage. Seems fairly idiot proof (good for me!)
  7. #287
    Administrator
    Enterprise Alabama
    Which plastidip did you use?
  8. #288
    OG plastidip
    Performix brand. Gallons have blue label with yellow lettering (from ebay; from Amazon can is unwrapped with plain white label). Haven't tried other products.
    turbomacncheese, it's easy to get off, as long as you put enough material down! Right now I'm at about 6-7 coats total. The first two or three are very thin - and I could see a problem trying to peel off at this stage. After the 'base' has been laid down the other coats build thickness pretty fast, and peeling at that stage is (too) easy.
    the only problem I have with 'dip is it's too fragile. Rubbing will pull up the material, which is too easy to do when fitting panels, I'm of a mind that 'dip should be applied after the bodywork is installed. Don't treat is like paint -it isn't. It also shows scuffs which invariably happen when building or fixing the car.
    The good news is after a thorough clean I was able to re-spray and get a nice finish again.
    Thanks everyone!
  9. #289
    Mechie3's Avatar
    Indianapolis
    Did you use three rivnuts per hinge? Two go vertical and one goes horizontal. If you only use two on the top you're putting a huge moment on the rivnuts which would pull them out. That's where the horizontal one comes in to prevent that.
    Zero Decibel Motorsports
    Check out my new website!
  10. #290
    ahha, user error! (2)
    Let me see if I can get a rivnut into the back of the bar and drop some JB weld into the existing rivnut holes and get this stabilized.
  11. #291
    Mechie3's Avatar
    Indianapolis
    I'm working on getting a tech page setup for my website with install instructions for everything. Sorry I didn't let you know earlier.
  12. #292
    Tease
    finishing details... soon
  13. #293
    QC, Canada
    Mike did you install the hinge brackets directly on the hood or you use something to flatten out the surface (hood is curved, hood hinges aren't)?
  14. #294
    Stacks of washers. I bonded the studs directly to the hood and use different height stacks to fill the gaps.
  15. #295
    OG plastidip
    Thanks everyone!
    Thanks. I suspected that might be it, so I'm glad you agree.
  16. #296
    QC, Canada
    Tnx for your response Mike, quick and easy idea, I might copy. I'll send you money for your patent.
  17. #297
    I think all the parts are there...
    Won't say done; but here it sits... pretty much fully assembled:
    I've scheduled the state inspections required for Maryland registration and titling... near the end of October; so it's another hurry up and wait. Doesn't look like I will get any track time this year, but I should be able to do some street testing as soon as the car is plated. I have some ideas of things to address in the short term and over the winter.
    But for now... garage queen.
  18. #298
    QC, Canada
    Whatever emoji for thumbs up.
  19. #299
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Congrats Mike! Why no track time? Due to registration or season change? If registration, you can always just tow it on a rented u-haul trailer to the track.
  20. #300
    thanks Hindsight,
    reasons for no track this year is pretty much all time related:
    -No tags mean I haven't been able to drive more than around the block, so the car's never been over 35(ha) MPH. I won't take this car on the track until I do some regular to high(ish) speed driving; not confident enough in the build yet.
    -There are no available sessions at the close track; I think the only thing left with the organizer I have run with in the past is at VIR, 5 hours away.
    -I don't own a trailer, or even a vehicle that can tow... that may change someday in the near future
    -I'm c#ickens#it (ha)
  21. #301
    Freeport, ME
    Mike, make sure you put many coats if you want to be able to strip it easily. I did one of my Miatas as a test case with a Plasti Dip experienced friend. We did 9 total coats on a Miata, about 3 1/2 gallons of dip.
    Dan
  22. #302
    Yup, got it! I have enough material to strip later! (I know since I've pulled some areas to respray). Definitely one of the important FAQ's about 'dip
  23. #303
    Leesburg, VA
    How about some out of the garage photos? Have you checked out summit point? I can understand not tracking it without some road miles though.
  24. #304
    Bad Hair Day
    Fair Enough !!
    Yesterday afternoon was pleasant, the sun finally came out and so did the big camera.
    (no idea why banana... FIL's work)
    (shot to scale: I'm 5' 7")
    I also ran the engine for 30 minutes and took a quick neighborhood spin; there is still some heat coming through the firewall from the engine bay, which itself gets quite hot. I will need to look at better sealing off the firewall and adding some more insulation.
    Driving was good! After fixing the alignment issues and making sure the car was set up square front to rear I can say it feels nice and planted when I leaned into the go fast pedal. There is a little 's' section to the road I live on and while accelerating the car reacted well to direction changes. Also, the LSD is doing it's thing out back. I definitely feel it at slow speeds. Going to be interesting when I start taking corners in anger.
    So the exhaust is pretty loud -knew that. Audience could hear the car around the corner long before seeing it. But in the car the most prominent noise is actually the turbo when it comes on... lots of fun there!
    Summit is actually the closest track, but their schedule is also the most limiting. I'll take another look at the various leagues that run there...
  25. #305
    Freeport, ME
    Mike, have you checked your headlight alignment? I've struggled to get mine high enough and aimed properly.
    Dan
  26. #306
    Leesburg, VA
    There we go! The coupe roof looks great! Is it me or is the front lower than the rear? The wheel gaps look bigger out back.
  27. #307
    QC, Canada
    Love the yellow door handles and gauge bezels! Yellow on black really stands out!
    What 3rd brake light that?
  28. #308
    QC, Canada
    I noticed it too, I think it's the tire size.
  29. #309
    yea, back is riding a bit high... but it's cool! If it's good enough for the Red Bull F1 team
    3rd brake light is an ebay special, Red 24 LED 12V car high mount third brake stop tail, basically this:
    http://www.ebay.com/itm/Red-24-LED-1...item35df24ecf7
    Headlight alignment is still on the list to do. I'm hoping since they're aftermarket there will be enough adjustment to get it fixed.
    thanks all!
  30. #310
    Atlanta, USA
    That car looks bad a** in matt black.
    Great build.
    Martin
    Previous forum name was "Fezzek"
  31. #311
    Baltimore, MD
    Good job! I am actually in maryland as well and currently working on the body. Please let us know how the titling and registration goes. I'll probably PM you later to find out additional details once my is closer to ready.
  32. #312
    Westminster MD
    looking good, Mike! I will have to catch up with you some time and see the progress in person.
  33. #313
    Senior Member 6t8dart's Avatar
    Apr 2015
    Irving, TX
    That thing looks plain evil in black...but im not so sure about the banana glued to the roof, it might attract hoards of monkeys whenever you stop.
  34. #314
    Quote Originally Posted by 6t8dart View Post
    Plain evil is the best kind of compliment, thanks!
    Banana... eh what's an imbecile like me going to do
  35. #315
    Hindsight's Avatar
    Atlanta
    Mike - Love it! I love the old front end with the hardtop. Very cool looking.
    Dan - RE the headlights - the only way to get them aimed right is to get some retrofit projectors. I have some sitting on the shelf waiting to get installed. Will post a writeup.
  36. #316
    I really like the matte finish and agree it looks plain evil. I've now added matte black to my short list of colors.
    Mike, I'm having trouble getting the top edge of the power window to seal against the felted molding so if you've got any hints, I'd love to hear. OTOH, all your photos have the window down so maybe you're having the same problem.
  37. #317
    windows are annoying!
    Quote Originally Posted by AZPete View Post
    Drivers side lined up pretty good, but passengers side has about 1/8" gap between the window and the felt molding. I am going to be heavily reworking the doors & windows over the winter to correct the door alignment/twist and get them to open/close freely.
    I'm not thrilled with the windows: cutting the slot in the door skin was really sketchy and I don't feel like the results are good enough. Add to that I don't feel the window rail path is correct for the amount of 'curve' needed to get the window to follow the door line.
    I can tell you that I over-cut the opening on the passenger side, and this greatly affects the window path. I went back with some flat aluminum and epoxy to reduce the size of the hole and use the weather-striping to push the window in. Actually, the result from this mistake looks pretty good (to my eye), and I plan on using this method on both doors when I revisit the issue:
    It's not the best picture, but you can see that the aluminum is under the door skin and the weather striping actually sits on the aluminum.
    Another idea I found was by watching a Daytona Coupe build on youtube by The Wizard. He is adding power windows and has framed the windows to make sure they position correctly. I think a guide frame at the front of the window in the sail panel might help a lot as well as cleaning up the gap between the door and the HT:
    https://youtu.be/1d4cMa_u4e4
    Overall, the window guiderail mounts and rollers don't have enough adjustment for me to get the passenger window to tip in enough to close perfectly. Additionally, since the door skin is required to push against the window from the outside to 'hold' it in position it's hard to pre-fit the window and check the alignment of the guide rail/rollers - which again is very aggravating!
    Actually my drivers side fits well and I don't have the same problem with a gap... which is annoying since that's the side where the door has always fit worse. Go Figure.
  38. #318
    Thanks for the advice and also making me feel I'm not the only guy having trouble fitting the windows. I've only been working on the driver side, so far, but I cut the door in a straight line from molding to molding and then discovered the window is curved - duh, I should have checked first. Tonight I'll remove and remount the door at a different angle, fingers crossed. I haven't yet tried to fill the cut with the supplied molding but I'll try what you've done with an aluminum backer.
  39. #319
    Finally, this is the week for inspections. Cross your fingers for me everyone (please!). Tomorrow is MD state salvage (pay us sucker) inspection and Friday is safety inspection.
    Really hoping to have the car on the road by the weekend.
  40. #320
    Fingers crossed for you. Thanks for your help.
