Hello All,
I'm wanting to replace my water temp gauge with an aftermarket unit. Can I just replace the sender at the stock location without causing any ECU problems (bypassing/removing stock sender wiring)?
I believe the water temp gauge is behind the Alt, further back from the oil pressure idiot light correct?
