Does anyone know if wipers are required for Rhode Island?
Rob
Rob
In my State for replica's and re-creations, any original safety equipment that came on the original car is required.
Check with your State's DMV and ask if they have a Specialized Vehicle Unit that deals with antiques and replicas.
Also, I'm adding a back up lights just to avoid any silly issues when my car gets inspected just to avoid any hassle.
Good Luck From The Land Of Dixie!
You already have backup lights, the LED bulbs are duel use with the turn signals
Dan
Here is the link to the Kit Cars in RI (http://www.dmv.ri.gov/inspections/kit/index.php). In the listing it states "The kit vehicle you build must conform to all State motor vehicle safety requirements " but then you can't find any specific information on safety requirements. I owned a roadster (titled as a 66) and never had to have an inspection but it was originally built/registered in 2002 without wipers. I know another roadster being built now that also does not have wipers but has not completed inspection. I do know of one other roadster that did need wipers so he installed a set of hand operated marine wipers for the inspection and then took them off. I would call and get a specific answer if you do not want to install the wipers. I think it may vary based on who is doing the inspections. This is RI after all... Enjoy.
Note: I am down in Kingston and just put a deposit on a Type 65 and I will be installing wipers.
The answer is YES! (but a single hand operated wiper - passed) you also need headlights, high beam, turn signs, warning flashers, horn, heat shields for side exhaust, baffles for mufflers, emergency brakes and they will check the underside of the car! The last big one is bumpers..the quick jacks did not pass. need the larger covers. Not usre about the Type65 so I will be calling because I have not heard this one before. Enjoy and I would call ahead if you have any questions.
RI rejected the 818 today because they want airbag, bumpers, muffler, and wiper. They also said i need to fix the brakes, as they found a leak. I have spent many hours and gone thru 4 brass tees. Thought i had it so it no longer leaked but its still leaking. I need to discuss with them the airbag and bumpers, there is no way those can be done
In Ohio I had to do bumpers.
Had to be track width (about 60") and 4" high. I think lower than 22 from ground.
I guess there is a way to do bumpers! Looks pretty good too. Thanks
I'm not surprised on the bumpers, muffler, and wipers, as CT required all of those. The airbag could be a problem. Perhaps just install an OEM steering wheel for inspection, so it looks like there is an airbag?
BobNCincy's bumper is more thorough than ours. They just wanted "something" there for us was the impression we got. We also never did a front one because technically the front nose piece that is bolted on is a bumper (and CT never asked to see anything further). I think sometimes it depends on the mood of the inspector for what exactly they consider a requirement that day....
Tamra
First autocross 3/29/15
In Maine the law indicates a ton of stuff, however the "inspector" comes right to your house and attaches the VIN plate. That's it! The "inspection" is just drive it to your local garage and get an inspection sticker... I was amazed!
Dan
As for the airbag, they just wanted it removed from the steering wheel, even though it is not connected.
As for the bumpers, I spoke to the guy, and he said the boss said they will take the car, as is, without bumpers.
I had an exhaust made by DynoTune, and it works pretty good. Real quiet, so as long as emissions are good, it should pass.
I just got all new brake parts from RockAuto so I cannot see how they could fail the brakes. I think I also need to point out that they brakes are manual brakes, and not power brakes.
Did the wipers, came out pretty good, by following some links here on the forum. I even added the washer bottle, but I needed to get one from Tacoma since it is smaller, and the only thing I could fit. The wrx one is huge.
Why go thru the trouble of wiper motors... Have your passenger earn their keep.
https://www.youtube.com/watch?v=WevQlQ4wcPc
https://www.youtube.com/watch?v=wmPfUHpYZ_M
I added it just after the fan, and I ran the nozzle off to the side, with a small piece of aluminum, which is easy to bend.
See pics.
