Results 1 to 14 of 14
Thread: Anybody find windows that fit yet?
    On the S. I know the angle of the windshield isn't right for the coupe windows, and there is a gap. Has anybody fit the window with the S windshield in place to see what the gap looks like? Might be able to come up with a creative solution if it isn't too big. We all know people have tackled bigger problems here.
    Need a bit more description, because I've not seen the problem you describe. I have an S retrofitted with a C top. Can't remember if I used the S or C glass (got 2 front windshields), but i'm pretty sure they were identical when I had them back to back.
    Likewise, the side window glass lines up well with the A pillar, it just takes a lot of futzing to get everything properly aligned.
    I might be dense (check that -I am dense), can you post a pic of the area you are describing?
    Right, I guess that wasn't clear. English does that to me sometimes (majored in math for a reason, lol). I just want to know if anybody has solved the roll-up door window problem for the S. Last time I read anything, it was accepted that the S windshield raked back more than the coupe windshield, so the profile of the door-windows didn't match and would leave a gap between the door window and the windshield frame. I don't have any pictures, but I can probably photoshop something tonight if that still isn't clear.
    Banned
    Loveland, CO
    Knowing nothing about this car but having a lot of experience with power windows, I have to ask if the glass is flat or curved. Flat glass is easy to get made to any shape you want. Curved glass isn't. If the window is not something borrowed from a production car, you'd be wise to get FFR's take on the problem.
    Quote Originally Posted by turbomacncheese View Post
    Turbo,
    My first thought was, nobody has put door windows on an 818S (roadster) yet.
    Then I remembered that FFR said that you could swap back and forth between 818S and 818C with a few hours of conversion time. You may be the first to try this.
    The 818S windshield does not have a pocket for the door glass to fit into. So I would say, if your running around without a roof, keep the windows down.
    The rake of the 818s windshield is adjustable if you want it the same as the 818c rake.
    I have my windshield rake as low as it can go without modifying the factory bolt holes.
    Senior Member AZPete's Avatar
    Considering your recent post on your build thread, I guess that you are thinking about building an 188S but adding door windows, right? The side windows would add a lot of wind protection but, as Bob said, you'd need to make some sort of support for the front edge of the glass on the windshield post. When I get home tonight I can measure the windshield on my 181C to compare to the measurements given for the 818S windshield. I think they are close and, again as Bob said, the S windshield can be adjusted quite a bit. I don't know of anybody who has tried door windows on an 818S.
    I'm not sure about the dimensions on the 188 or the 181, but I'm pretty sure mine will be HEAVIER. But as usual, you are perceptive and that is the root of my question. I'm already spitballing ideas and watching a lot of fiberglass how-tos on the youtube. Haven't even ordered the damned kit yet, something must be wrong with me. I'll appreciate your input since I know you've driven both ways.
    Quote Originally Posted by DaveS53 View Post
    Pretty sure the 818 windows are from some production car or other, but not sure what.
    Turbo,
    Bob, thanks for the help here. Sounds like maybe the problem is THIS little triangle...
    and not the triangle I had imagined....
    I feel good about scenario 1. So good, that I may indeed be the first to try it.
    San Diego Ca 92106
    Will it be some sort of wind wing attached to the S windshield to fill the gap? I've been wondering what a wind wing would look like and perform like on the S.
    I'm not sure about moving parts. I'm pretty confident about something to fill the gap.
    Banned
    Not really, thinking through every gritty detail of a project like this before starting is something that not enough people here do. They'll daydream for weeks about how much horsepower they think they need but don't stop to consider if they're actually up to the task of assembling a car until it's sat in their garage for 3 or 4 years.
    As far as the windows, why not ask FFR what they are off? They typically don't have a huge interest in re-selling glass (it's a nightmare to ship) so they'll typically tell you so that you can source a local replacement if you break a window or windshield.
    Quote Originally Posted by phil1734 View Post
    I'm going to chat about it when I place my order. Seems like it shouldn't be a pain shipping with the kit, or they might suggest I could get a pair of windows cheaper from a wrecking yard.
    San Diego Ca 92106
    I've thought about that triangle area as a possible mounting spot for the mirror. Especially since some have had problems with body fitment in that area.
    That's how I intended to hide my amateur work, lol. I hadn't thought of that until yesterday when I realized that's right where the mirror is on my Hyundai, and where it was on the 92-x if I recall correctly. I'll post pictures of how it turns out. Shouldn't take more than a year or so
    And I thought I was the only guy who over-thinks way too much!
