This car is being built for one of our customers from Belgium.
Finally got to make some noise for the first time It's setup with a Coyote and 4R70W
Build photo's can be found here;
http://www.hamminkperformance.nl/for...php?f=48&t=210
Wow! That looks wicked. But I have a concern about that radiator shell. Is it really going to be that low to the ground or is that an optical allusion? Or are you just not to setting ride height yet? It looks lower than even the GTMs! WEK.
We adjusted the ride height as low as possible for a show we had a couple of months ago.
With the first start an go kart we didn't change it because it looks really cool.
And thanks for the positive comments!
