After an exhaustive search on both forums I am still at a loss. My rear end is a 1994 solid axle 8.8. I have the fox length axles and brackets from Richard (North Racecars). When trying to mount the calipers the spring on the calipers hits the coil over springs, not by a little but a lot. I have read on the other forum that some people have turned the coil overs upside down and/or moved the calipers to the front side of the axle. I haven't run any brake lines yet so a caliper move is no big deal except to keep the bleed screws on top. Others have put washers between the caliper and axle brackets, but the thickness I have read is all over the map. Are there any other options I'm missing ?
Thanks in advance, Mike
